-   -   need to change chip for headers with motronic? (http://forums.pelicanparts.com/porsche-911-technical-forum/1006465-need-change-chip-headers-motronic.html)
pjh69911 08-30-2018 06:57 PM
I have a 1986 with 3.2 punched to 3.6 with motronic. It was remapped. I have SSI and would like to go to less restrictive exhaust with headers. Can motronic adjust to the change or will the chip need to be remapped? Thanks
brianlay 08-30-2018 07:09 PM
Motronic with O2 sensor will adjust to part throttle but full throttle needs to be re-mapped.
pjh69911 08-31-2018 03:39 AM
Thanks, i figured that might be needed.
175K911 08-31-2018 03:55 AM
Definitely need a remap. Many years ago when I switched from SSI to George’s 1-5/8 headers on a 3.2 converted to 3.4, the custom mapping for the SSI caused a major flat spot in the torque curve on the dyno when bolting on the headers. Ran both back to back, big flat spot in the 3500-4800 range.
wildcat077 08-31-2018 09:26 AM
I have a 3.6 in my 89 with Fabspeed 1 5/8 headers , you are choking your engine with the SSI's which are basically suited for a 3.0 engine ...
Had Steve Wong come up with a custom chip for my application , happy so far !
darrin 08-31-2018 09:38 AM
how did you get to 3.6? bored and stroked? thought 3.5 was as big as one could go using a stock 3.2 crank?
Canada Kev 08-31-2018 06:24 PM
I believe 3.7 is possible (102mm bore should do it I think with the 74.4 stroke of the 3.2 crank) as LN Engineering makes cylinders of an appropriate size. However, and I don't know the numbers and other specific data, but I suspect the meat left in the case between cylinders might be getting pretty small after machining for the cylinder bore, not to mention the stud clearance.
