YAPM - Yet another phone mount...
I am considering the Rennline clock mount, but in the meantime, here's my setup using a magnetic mount attached to a piece of sheet metal on the bottom of the ashtray unit.
A reasonable compromise that gets me GPS and music interface without blocking anything. http://forums.pelicanparts.com/uploa...1535733190.JPG |
Very nice.
Can you show us how you fab'd and mounted the piece of sheet metal? |
The metal piece is formed to not touch the leather, so if I go to the Rennline there's no sign of it. (some might be queasy about drilling the bottom of the ashtray, but you could likely use VHB tape)
I am planning to make a sleeker version where only the magnet tab is visible. I'll post when I do... http://forums.pelicanparts.com/uploa...1535745935.jpg http://forums.pelicanparts.com/uploa...1535745954.jpg |
That's a sweet and elegant solution.....why would you consider something expensive and fiddly?
I dig it!
Meanwhile I’m going to try and waterjet a prototype of my original idea that would mount in a similar spot but be held in place by the closed ashtray. No drilling, and quickly taken in and out.
Love where this is going! Funny I used my ashtray slightly pulled out to rest my phone during a drive the other day. It’s a natural spot for a mount.
Any update ?
Unfortunately I haven’t spent any time on this...this version is working pretty well, so I’ve moved on to the long list of other little items the car needs... :/
hitting a bump, the attached weight to the ashtray is gonna snap drop it.... I guess.
Better to directly Mount the bracket to the knee line. |
I’ve only driven it with the mount a couple thousand miles, but luckily no issues like that.
Also, I don’t safari... :) |
I recently installed the Rennline magnetic mount. Works great for me. I have a Rennshifter that is 2 in longer than stock and I haven't hit my hand on the phone, I mounted the plate pretty low on the phone though. The magnet isn't strong as the Scosche one I have in my other car, but it's working fine.
Another Mouse Trap
http://forums.pelicanparts.com/uploa...1558366409.jpg
http://forums.pelicanparts.com/uploa...1558366531.jpg Took a piece of black flat bar, put in a slight bend and inserted between the vent and housing then slipped on magnetic clip. Don’t have to look down to view WAZE etc. took five mins, works great. |
^^^^^^Excellent!
Friction fit is enough? More detail please? Same magnet kit as the others used? |
Who makes the rubberized magnet, I see the S brand?
My passenger seat works great with the phone turned off.
| All times are GMT -8. The time now is 10:43 AM. |
