Speed Metal Army General
Strut housings.. What do I have here?
Hey guys, which housings are these? 3" Caliper spacing, no roll pins that I can see...
The green is throwing me off too. Not that someone couldn't have painted them green for kicks.
Old 09-01-2018, 09:05 PM
If you take the wheel off you should be able to read the brand and part number that is stamped on the housing. While the strut is at full droop, also check is the gland nut at the top of the housing to see if it is internally or externally threaded. Porsche changed from one to the other in early '85. That should give you all the info you need to get the right inserts.
Old 09-01-2018, 10:26 PM
That's full droop on my lift.. Looks internally threaded?
Old 09-01-2018, 11:42 PM
