84911 will not start
Just back from a two hour drive and the car will not turnover. No turning over just a buzz noise from the engine compartment. Any suggestions?
Check batt connections
+1 check connections and voltage. You need to be over 12.5 volts
Your starter may be heat soaked. Get under her safely and tap the solenoid attached to the starter. To confirm starter issue, push start her. Won't take much of a push, heck, I did it in reverse when my starter went out when facing in, in a parking spot. Break a Leg, Jim |
Cheers, Joe |
| All times are GMT -8. The time now is 04:23 PM. |
