another 3.6 fuel line question...
recently replaced all my fuel lines and i noticed when i first tried to start the car that there was fuel coming out of the fuel filter (in the engine bay). i tightened the banjo bolt and if i nudge the hose i can hear pressure leaking from the hose fitting. i have this type of fuel hose clamp (see first pic).
![]() are there special requirements for clamps rated for fuel injection due to working pressure? thinking i need to replace clamps to this style, thoughts?
1967 911 (Azzuro Thetys) - #308439 1971 911 (PTS Black) - Built 3.6 Sleeper 1989 911 (Grand Prix White) - Cabriolet Bone Stock Last edited by G50911; 09-03-2018 at 07:01 AM.. |
60 PSI is what your dealing with.
Crimped hose is usually used.
1980 911 - Metzger 3.6L 2016 Cayman S |
Those top clamps are pretty useless.
swapped out the 4 in the engine bay today (supply to filter, filter to regulator line, regulator line and return. i noticed the shop also used the "bad ones" at the tank. i guess i need to trace them throughout the system and replace them. (#*$%&!)
1967 911 (Azzuro Thetys) - #308439 1971 911 (PTS Black) - Built 3.6 Sleeper 1989 911 (Grand Prix White) - Cabriolet Bone Stock |
