Raido/Base Problem
I have a 88 911 3.2. I have an Infinity baselink in the audio system and for the past 3 years has worked great. I now have a problem, with the REM hooked up there is a horrible base hum comming out of the unit. Disconnect the REM and the hum goes away.
Any clue what I should be checking? Thanks in advance Marty |
Check the ground, if you have multiple grounds on your sound system it could transmit distortion or feed back. Use a volt meter to find the best ground point.
My Sub did that before I used the same ground the head unit used. |
| All times are GMT -8. The time now is 07:19 PM. |
