1981 911 sc throttle pedal bushing
Hey all, my first post. I just purchased a 1981 911sc, my first Porsche, I am loving it, but I need a bit of help.
Can anyone tell me what part numbers to order as replacements for the parts circled in green (numbers 24 28 and 30)?
These are the bushings that go on the throttle mechanism beneath the pedal.
Mine are missing, so there is all sorts of play in the linkage.
Old 09-07-2018, 08:43 AM
Steve F's Avatar
Thumbs up
Welcome :<) 81 owner also #28 is part # 901.423.253.01...working on the other ones.
Opps, I think that was for the pedal, sorry.
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate
1967 912-1985 Toyota FJ60 Landcrusier
1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4
1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag
1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS
Old 09-07-2018, 09:39 AM
New-ish 911SC Targa Owner
pampadori's Avatar
you can download the PET (porsche published parts catalog in the form of a PDF) here: https://www.porsche.com/usa/accessoriesandservices/classic/genuineparts/originalpartscatalogue/
Look at page 304
901 423 253 00 Bearing sleeve
900 021 008 00 Cotter pin
901 423 193 00 Rubber stop
The picture you posted is different than what is in the PET so not sure which is right.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 09-07-2018, 09:49 AM
Thank you guys! I ordered Part #: SIC-423-341-01 because it's called a pedal bushing kit, but I think its actually only a clutch and break pedal bushing kit.. Am I wrong about this?
I don't have the car at my location to check if they will work.
Old 09-07-2018, 10:11 AM
I think that's the right kit. It contains all the bushings for the pedal cluster, including the ones that are missing on your car. You'll probably need to rebuild the cluster at some point anyway.
Old 09-07-2018, 10:18 AM
okay great, I'll play with it this weekend. Everything else with the pedal assembly looks brand new, shiny not a spec of rust.. it looks like it was assembled by someone without these two bushings for some reason. I hope this kit is correct because i only get one day a week to work on it
Thanks again!
Old 09-07-2018, 10:29 AM
