testa-rossa's Avatar
Help with Fog Light on ‘85 911
Hello,
I have an 1985 911 with turbo flares welded on. I’m almost finished with my project but need some sort of fog light solution to make it complete. Any ideas? I’m leaning towards something that looks close to factory. The car has wiring for fog lights but the previous owner/s put on turbo flares and a new valence so I’m not sure what would fit.
I really don’t have the time to do this myself. I’d love for someone to make this for me in exchange for money and fame
Tyler
Old 10-01-2018, 11:30 PM
IMO, without the whaletail, it would keep the lines clean if you kept it without the (useless) front fog lights.
Old 10-02-2018, 01:59 AM
Formerly known as Syzygy
Canada Kev's Avatar
Same opinion. I'm actually considering using an earlier valence on my 3.2 to eliminate the fogs.
Yours looks great as is.
Kevin
Old 10-02-2018, 05:16 AM
7783911's Avatar
unless you move towards modern fog lights, they tend to be useless..your front end looks great as is!
Old 10-02-2018, 08:24 AM
Banned but not out, yet..
RSBob's Avatar
I use my useless fogs as daytime running lights so they have a real function.
Just order some 1982 fog lights which are very easy to mount and find a shop to wire them Should take an hour tops.
Old 10-02-2018, 10:16 AM
Ok, thanks. I get that they are useless. I just always figured the car was a little naked without them.
Old 10-02-2018, 11:06 AM
Runnin on empty
acme911's Avatar
I have a set with mounts if you want. PM me. I was running them as DRL’s.
'74 911, Steel Wide Body Hotrod, 3.0, Jenvey ITB’s, AEM Infinity, KW V3's, Eibach Sways, JWest shifter and other stuff.
https://forums.pelicanparts.com/porsche-911-technical-forum/1006126-midi-modded-bumpers-led-headlight-manifold.html
Old 10-02-2018, 11:24 AM
Only issue I see is filling the mounting holes in your front valence
Old 10-02-2018, 11:45 AM
gumby's Avatar
I agree with no fog lights, keep it smooth a body shop can weld the holes and reform and smooth the valence ....
Ron
73.5 T
74 R90/6 (Tupelo Honey)
86 Carrera (Plan B)
1987 BMW K100RS Motorsport
Old 10-02-2018, 04:13 PM
(man/dude)
Jonny042's Avatar
Your car appears to have an SC or earlier valance? - An 85 would have had the integrated fogs which in my opinion look pretty good and finish things off nicely.
My 85
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 10-03-2018, 06:12 AM
