Spacers for an '87
I have 6s and 7s Fuchs. 205/225 RE-71Rs. 1987 narrow body.
Suspension is essentially Turbo/ROW. I would like to put on spacers front and rear to get the stance just right. Suggestions re: type/size of spacers, front and rear; length of studs required, etc. greatly appreciated. TIA!
87 Carrera/Guards Red 99 Carrera/Arctic Silver (FSI Stage II 3.6 build) 04 Honda RC 51/ Nicky Hayden edition 07 Honda CBR 1000RR 13 Aprilia RSV4 Factory |
something I have done was measured the distance from the top of the tire to the edge of the fender... and then created a small wooden plated of that same size... drilled some holes for the lugs and put on my hub and mounted the wheel to give me and exact visual.
Seems like a lot of work, but this allowed me to get an EXACT size spacer to make the wheels fit just right.
1987 Porsche 911 Carrera Coupe |
H&R TRAK+ 23mm Wheel Spacer Pair - DRM Style, Bolt Pattern 5x130mm, Center Bore 71.6mm, Thread Type 14x1.5, 1987 Porsche 911 Coupe Part #: HR-4695716 ![]() ![]() Ctopher |
Thanks, ctopher!
Looks good!
Did you have to install longer wheel studs to accommodate the 7mm front spacers? |
