Jameel's Avatar
Shifter rotation orientation?
Been playing around with getting my shifter into it's best position. Turned a shifter extension ala John Walker (I'm a tallish guy) but now it's digging into the side of my fat leg more since it's higher. Also have sport seats, so I'm lower in my body position. I noticed that the upper half of the shifter (the dog leg) is pointing towards the driver a bit, not straight back. I noticed this in my brother's SC as well. I know these tend to come loose down below, so I'm wondering if someone got the rotation wrong during a repair. Anyone know what factory setup is? And if I want to rotate mine away from my fat thigh, I assume I have to rebraze/weld down below?
Old 09-08-2018, 07:38 AM
wareaglescott's Avatar
Cant answer your question about adjusting it but I did go look at my '79 SC and when mine comes straight back it is in alignment with the parking brake handle not slanted off to drivers side like yours.
Old 09-08-2018, 10:51 AM
Jameel's Avatar
Thanks for looking. Hopefully we'll get some others to chime in.
Old 09-08-2018, 11:20 AM
7783911's Avatar
ever consider turning a few extra extensions and selling?
Old 09-08-2018, 01:17 PM
If you need something custom made and turned I have used this guy. Very nice quality work and a good guy.
https://www.lathewerks.com/?SID=tv8bjsa4ap423s6krd145cq8sv
Old 09-08-2018, 01:38 PM
Sherwood (911pcars) from Seine Shifters also sells shift stick extenders
that work great, see here:
Yet Another Shifter Thing
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 09-08-2018, 01:52 PM
Heat the shaft with a torch below the boot and bend it over to where it clears your leg and the seats
206 637 4071
Old 09-08-2018, 01:59 PM
Jameel's Avatar
As always, thanks for the great advice John. I heated it up right above the dog leg and eased it over until it was pointing straight back. Put my extender back, went for a drive and.....aaaaaaaahhhhhh!! No more leg interference at all. And the shift knob falls above my leg now instead of right in the middle of the thigh. I rather enjoy the reduced effort as a bonus. Shifts are a little longer, but easier too. One of the best mods I've done to the overall comfort and ergonomics of the car. 2000 miles to Rennsport here I come!
1983 SC Coupe Chiffon White
3.0 rebuilt by me
9.5:1 964 Cams. SSI's. Backdated heat. KEP sports clutch.
Old 09-11-2018, 03:24 PM
It all depends. The shift lever is a two-piece lever joined by an epoxy-like glue.
The factory alignment is straight back along the fore-aft axis of the car. At some point in time, the top half separated and was re-attached to the lower part.
- If weld-repaired, your reheating and bending to realign should be good.
- If re-epoxied, your reheating could have compromised the bond. Depends on the amount of heat and where localized.
Inspect the lever joint for signs of a weld bead. If visible, you're good to go.
Sherwood
Old 09-11-2018, 06:30 PM
911 enthusiast
tmadden2's Avatar
I’m interested to hear more about how that cell phone magnet is mounted. How did you attach it to what appears to be the HVAC panel?
Old 09-11-2018, 07:10 PM
Jameel's Avatar
Sherwood
Great info! I will take a look.
Old 09-11-2018, 08:00 PM
Jameel's Avatar
Camera angle. It's the Rennline clock mount.
Old 09-11-2018, 08:01 PM
Flojo's Avatar
hope that heating and bending it will not brittle the shaft and hope it does not break when doing a hard shift...
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 09-12-2018, 03:04 AM
