Riebe M70x70 mm for rear caliper
While splitting a set of 85 Carrerra rear calipers I damaged one of the M7x70mm bolts and need help either with getting a second hand caliper or just bolt and nut. Any advice on this ?
80SC (ex California)
Old 09-08-2018, 08:50 AM
Harpo's Avatar
The M7 bolts are very hard to find unless you just buy another caliper. Eric @ PMB might be able to help you
Old 09-08-2018, 08:54 AM
M7x70 mm with torx head BMW 11127535024. Torx Bolt Part #: 11-12-7-535-024-BOE at 2.25 from our host via BMW pages. Flange would have to be trimmed down and don't know pitch but have never seen anything but 1.0 pitch
German seller tola-tools-de has M7 but unfortunately dont sell out of Germany....
Zylinderschraube M7x70 DIN 912 12.9 brüniert. This one is with allen head and might work. IF I could get my hands on it
Found M7 nuts on amazon; Mutter M7 DIN 934 DIN934 M7x1,00 Regelgewinde für MZ Simson Minarelli Piaggio Vespa
Old 09-09-2018, 04:47 AM
(man/dude)
Jonny042's Avatar
Very resourceful! Great find on the BMW part.
Always wondered if they could be drilled out to M8, myself....
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 09-09-2018, 06:41 AM
Vintage Owner
Jack Stands's Avatar
I always wondered why ATE used such an 7ncommon sized fastener.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 09-09-2018, 10:16 AM
rollandburn's Avatar
I went through this, called everyone/everywhere... ended up taking the board’s advice and drilled the bolt holes in the callipers a smidge larger then used readily-available bolts, fit perfect.
Sent from my iPhone using Tapatalk Pro
rollandburn1985 911 Carrera
Old 09-09-2018, 05:48 PM
pictures of modified BMW M7x70 mm bolt part no 11127535024 and corresponding torx bit. Both trimmed down on my lathe and fit perfect ! The bolt is threaded the whole way and may be used on all rear calipers using 7 mm bolts
Old 09-10-2018, 11:45 AM
