LinkBack | Thread Tools | Rate Thread |
Hi
3.2 Intake Insulators Gaskets
"A good sense of humor is the best thing to have in your toolbox when working on these cars." Quote by Charles Freeborn, Pelican. |
I didn't use any.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
abides.
From the engine sealant thread:
Graham 1984 Carrera Targa |
Diss Member
Using Porsche's stock parts you use a gasket top and bottom of the insulator with no sealant.
But I'm not inclined to disagree with Henry. I do wonder if he seals the insulator down so it stays in place during occasional manifold removals on a race engine.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Member 911 Anonymous
Sealant
I used this upon recommendation of several veteran re-builders, brown tar like stuff:
Just a very light coat, you don't want excess to go down the intake.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
I have seen, because of the wall on 3.2 gasket being thin, the gasket side pull into the intake and cause a vacuum leak.
I do replace the insulators when building with new and don't use sealants. Bruce |
Another gasket sealer is "GaskaCinch"; looks like very thin rubber glue, applies with included brush and easy to remove.
Sherwood |
Schleprock
It's wise to flatten the insulators on a piece of glass (or something else known to be legitimately flat) with some fine grit wet-sand paper. If the insulators have some rough edges or nicks on their surfaces, this can invite the gasket to leak. Not to mention the 3.2 intake is notorious for showing loose barrel nuts.
Kevin L Present: '86 Carrera, '79 911SC widebody conversion rolling racecar shell Past: '87 Carrera |
Hi
Thanks for the input.
Thread Tools | |
Rate This Thread | |
