-   -   Spark plug wires sparking in the dark - source of misfire (http://forums.pelicanparts.com/porsche-911-technical-forum/1007780-spark-plug-wires-sparking-dark-source-misfire.html)
Marwil 09-13-2018 09:10 PM
Looking for some input here. I have been chasing down a persistent misfire on my 78 SC (80 SC engine).
The setup: 1980 SC engine with a top end rebuild 20K ago. Converted to Megasquirt 2 - fuel ratios appear stable. Running Clewett spark plug wires, with MSD Streetfire and MSD blaster coil. Plugs are NGK BRP7EIX with standard gap. Using a standard ignition rotor (with a resistor) in the rotor.
The Situation: Engine generally runs well but at 2800 to 3200 stay state a misfire/stumble sets it that I can't seem to eliminate. There is also an odd vibration when coming off the throttle at similar engine speeds. I've checked ratios, MSD wiring, plug connections, grounds, sensors, etc. with no change in outcomes.
Tonight I turned off all the outdoor lights and looked in the running engine compartment and there were a myriad of tiny sparks coming off plug wires primarily on the drive side of the engine. The Clewett wires are only 4 years old - could they be bad? Passenger wires spark slightly nearer the coil but not near the right side or the plugs. The sparks are not huge but there must be at least 15 small points of sparking.
1) Is this the likely cause of my misfiring? Why would 4 year old Clewett wires be doing this? Does the fact that I didn't increase the gaps on the plugs force the sparking?
2) I thought larger plug gaps would increase the resistance and would likely force the sparking?
3) Does using a resistor rotor increase the likelihood of sparking/misfire?
I don't want to just throw money at parts but would replacing the plug wires be a safe bet, and what would you recommend for wires?
Looking forward to your input folks.
Mark
DRACO A5OG 09-13-2018 09:20 PM
I would put the plugs back to spec and see if the wires still spark or check the OHM on the wire set.
Next would be is to go back to OEM Berus, I did from Magnacors back to Berus due to wires not seating properly on the plugs.
Marwil 09-13-2018 09:50 PM
When you say put the plugs back to spec, do you mean use stock plugs or the factory plug gap? I’m currently using the factory gap on the NGK plugs I have installed.
Interesting thought on the Beru wires.
DRACO A5OG 09-13-2018 11:00 PM
I thought I read you did not increase the gap, so you are at factory gap? Good.
Then I would remove the wires and check the OHMS on the wire set. Obviously, there are issues with those wires. Are you sure you are fully seated on the plugs and dizzy? On the plugs you should hear/feel the click and on the dizzy, insure there is no air trapped under the boots. Use a pick tool to probe under the boot and try the night test again.
The problem with my Magnacors was it kept popping off #2 plug. Got sick of pulling over to re-seat the plug. Back to Beru, no more issues.
Quicksilver 09-14-2018 02:40 AM
Part of my standard install setup for plug wires is to seal the whole system with dielectric grease. In addition to the normal sealing of the boots to the plug and coil, it also includes sealing the boots to the wire. Push the boot just a touch up the wire and grease the seam and then push the boot back down.
A well sealed boot should hold air pressure which will cause the boot to pop off. You need to pinch/squeeze one side of the boot to burp the air out of it so it will say seated. The plugs are a bit harder. Rocking it from side to side helps some but what really solves it is going through a heat cycle to bleed the trapped air out from under the boot.
A quality set of wires prepared like this will run under water. I have a set of 15 year old Magnecor wires that have never had an issue through rain, car washes, and any other abuse.
But...
The second you start to get sparks jumping you now have a problem with carbon tracks. Once you have a carbon track started it is likely you won't be able clean it off and if you can't remove the alternative path you have to replace the part.
brighton911 09-14-2018 04:35 AM
If your wires are good, you should be able to give them a light spray of water without any sparking or stalling. If you can see spark leakage dry, those wire are toast. There is a local guy that was making up wire sets using your ends, PM me if you want his contact info. Also, it's not too hard to do it yourself, I do have some extra wire "in stock".
morrisjm1 09-14-2018 05:16 AM
Mark,
I had a similar problem a few years ago. The OEM wires had failed, I went with Clewitt wires and it ran great…until it rained. Replaced those with Magnacor. Problem solved. I was too cheap to buy the OEM ones in the beginning and ended up spending a bit more overall.
If you’re seeing sparks, the wires are bad.
Mike
RedCoupe 09-14-2018 07:58 AM
Do you have wire separators installed? I just installed a set of Clewitt wires on my 86 and found that the factory wire holders and separators didn't fit the fatter Clewitt wires. So, I went to a FLAPS and bought some generic holders from the hot rod section of the store to keep the wires properly separated. If the wires aren't separated misfiring can occur due to inductance.
fintstone 09-14-2018 08:12 AM
I have never seen the little electric light show unless the wires are bad.
76FJ55 09-14-2018 08:51 AM
I agree with the previous responses that when you start seeing arcing the wires are bad. In regard to checking the resistance of the wires; at this point it is irrelevant. the core conductor could be well within speck but in your case the failure is of the insulation not the conductor.
DRACO A5OG 09-14-2018 11:01 AM
Here you go, how to check resistance for the wire set:
http://forums.pelicanparts.com/porsche-911-technical-forum/1007675-multimeter-help-needed-spark-plug-wire-resistance.html
Jonny H 09-14-2018 12:14 PM
Part of the problem is the stupidly high voltage (~500V) that MSD use on the coil primary. This results in 50,000V on the plug wires. The higher the voltage, the more likely it is to ‘jump out’ of the wires (or take an easier path to ground). If the wires are close together (like over the fan housing) this can even result in firing the wrong plug!
Porsche CDI systems use a mean voltage of around 30,000V and the components are designed around this. Sometimes more isn't necessarily better.
Marwil 09-14-2018 10:10 PM
Thank your for everyone's replies. Based on the responses it seems that:
The wires are toast if dry sparking.
Wires should be well separated and sealed - which is currently the case though minor sparking was indeed seen at a point on top of the shroud.
The Streetfire might operate at an unnecessarily high voltage, perhaps provoking sparking.
So:
New wires Magnacor or locally sourced - Brighton911 please pm me the contact info.
Reinstall the original CDI - I would like to go Classic Retrofit but will need to rebuild the war chest Jonny.
Seal and separate the wires well.
Mark
DRACO A5OG 09-14-2018 10:23 PM
If you have your old Beru wire set, take the dust boots off and use the Magnacor don't last. Ask me how I know. Maybe they changed but, it is what I experienced with the dust guards/boots
Another thing is Magnacors are thicker so be aware the wire holders may not fit right.
Sowwy to be a downer :-( on the Magnacors. I really loved them in the beginning.
Use the pick tool to get all air out of the plug connectors on your dizzy and use some dielectric grease to make sure they are properly seated.
Break a Leg Brother!
Marwil 09-23-2018 11:15 AM
Installed the Magnacors and they are staying on the plugs :D. Significant difference in idle, at speed and off throttle. My misfire seems to have been cured and as an added benefit pops and bangs on decal and part throttle have backed off to an appropriate burble. I should have cleaned the plugs when I installed the wires just to eliminate any fouling issues but I was too eager to see if new wires would have an impact. I think I'll now be able to focus on the fine tuning of the MS 2 given the reduction in other running "noise". Thanks everyone for their input.
Mark
Fred Winterburn 09-23-2018 03:32 PM
Jonny, You beat me to it. Plug gap does not adequately control the voltage with a CDI. The voltage needs to be limited and controlled at the source, as your CDI does. Fred
Marwil 09-23-2018 05:36 PM
The takeaway on the CDI discussion is either a well serviced and functioning Bosch CDI or Jonny’s CDI+ are more than up to the task. If I chose to continue with my MSD for the moment I am probably best keeping the stock gap on the plugs so that voltage Is dispersed more efficiently than with a larger gap. Jonny and Fred you might have to edumacate on this latter point.
Mark
targa44 09-23-2018 09:18 PM
Marwil - you probably know that DIY autotume recommends Magnacore for the MS. I just can't get an answer to which product.
What did you use? 7mm, 8mm, KV85? or other?
thanks,
Marwil 09-23-2018 09:25 PM
Targa44 -Nope, didn't know that, looks like I stumbled in the right direction. I used the KV85 wires and didn't have any trouble fitting them.
OsoMoore 09-24-2018 12:50 PM
I had a similar issue a few years ago, with a similar conclusion. Long story short, buy the more expensive OEM wires/gears/rings/whatever or you'll spend the difference and more in time and frustration.
JackOfAllTrades 10-02-2019 05:21 AM
Help with sparking ignition wire!!!
I have a question related to this discussion. So I'm headed into my late 20's and am an Electrician by trade. Started learning the trade when I was a kid, going to work with my grandpa's company whenever school was out, and even started and worked full time for him starting the summer before my Jr/Sr year in HS (I graduated a year early,) and have worked for a few different companies since then. I had no older male figure in my life growing up besides him, but he only knew electrical for the most part. Not much of anything else. Because of that, I've pretty much always had to learn by teaching myself, how to fix everything and do all the work that came up over the years (my family would also NEVER hire professionals of anything. Always had to either know somebody, figure it out for yourself, or just go without whatever the situation was at any given time.) So, I know a decent bit about many different trades & skills, that I have mostly taught myself over the years. This includes mechanical work. Ever since I was 17 I have always fixed my own vehicle. Now I seem to have become the family mechanic (or really the family handyman.) When it's something new, I research the internet, study the area of the vehicle that I'll be working on, and figure it out. I haven't failed yet.
I just want you to keep all that in mind when you read and possibly reply to my question below.
So yesterday, my smallest truck started doing the same thing as what happened to the guy from this threads original post. The "Check Engine" light also started to come on and blink last night. It's a 2005 Ford Ranger, 5-Speed, with the medium sized factory engine (just the regular V6.) I haven't had it long so all the parts being used are still pretty much factory standard.
When I had a second to look under the hood late last night, I could tell it was coming from the engine, but I couldn't figure out where or what exactly was the issue...
UNTIL I SAW SOMETHING ELSE!!! I had this truck sitting in my 2nd driveway around the side and back of my house where the only light back there is a flood light on a motion detecting sensor switch. Right before I was about to close the hood, turn it off, and give up, my flood light happened to go off from lack of movement. When it did, I was looking down and around my engine and saw 2 small lighted sparks. Upon further investigation, I seen that these 2 sparks are coming from one of my ignition wires. Where the wire feed turns at a 90 degree angle, is where the 1st spark location is. That specific spot is sitting right next to/on the metallic side of the engine. Me being an electrician, my first thought was that tge insulation had a open knick in it and that is what was causing that. The 2nd location was just about 4 or 5 inches further down on the same wire, right there almost where the wire is terminated into the spark going into and feeding the engine. Because of that and my initial thought process on the 1st location, I thought the same thing with this one. I figured there was an open knick in the wires insulation right there at its termination.
Heres what I'd like to know...
(1) Could it be a knick like I 1st thought or no? And if so, would just insulating those 2 small spots fix my problem?
(2) Is my ignition wire actually bad and need to be replaced (Because it's only that one wire sparking and none else.) And if that's the case, have all my ignition wires gone (or are going) bad and need to be replaced? Or just that 1 wire?
PLEASE PLEASE PLEASE PLEASE PLEASE, can somebody HELP ME out and give me some information? Everything I find on the internet has people saying all kinds off different opinions, solutions, and ideas & none of them either make much sense or are described well enough...
Thanks in advance for any and all help/advice that anybody may or may not offer up!
God Bless!
911pcars 10-02-2019 01:19 PM
With regular points and coil ignition (Kettering ignition), the secondary voltage produced from the coil is dependent on what is needed to jump the spark plug gap. Thus, a larger plug gap (or other secondary resistance i.e. broken conductor wire, bad/dirty wire connections, etc.) can increase the voltage requirements. If the secondary system insulation is suspect, voltage will leak to ground as needed and a spark plug misfire is the result.
Same with later CDI and related ignition systems, except voltage output is higher. This is a plus in the spark creation area, but can also be a bummer when the high voltage energy recognizes an easier path to ground. Make sure insulated system parts are doing their job.
Here's an excellent article on the basic ignition types and a discussion of performance-related operation:
https://www.jetav8r.com/Vision/Ignition/CDI.html
Sherwood
911pcars 10-02-2019 01:25 PM
Sherwood
jlex 10-02-2019 03:41 PM
Just get a piece of vacuum hose with enough diameter to go around the wire. Split it lengthwise and fit it over the wire. Should act as an insulator on that wire. I wouldn't replace them all unless you start to notice sparking on the other wires. If you really want to spend money, go ahead and buy a new set as your original set is now 15 years old.
kltarga72 10-02-2019 04:59 PM
911pcars
thanks for posting the URL, a good descriptive article.
jackofalltrades
I think you and i were raised in the same environment. In the old days when a mechanic found a plug wire that was shorting to ground he would cut the correct length of wire from a 100 ft. roll and make the cheap repair. Of course this was before solid state ignition systems.
My background was in electronics from old tube theory, transistors, integrated circuits, to digital.
When my friends have electrical problems with their cars quite often I will ask them if they have clean engine and battery grounds.
Poor grounds can cause a variety of intermittent electrical problems.
When the current jumps the gap on the spark plug it makes its way to engine ground which then has to find its way back to the battery. Current takes the least path of resistance so worn out plug wires will arc to ground especially when ground wire connections are rusted or corroded.
Lash
manbridge 74 10-02-2019 05:59 PM
Many guys forget the ignition system is a system composed of multiple parts needing attention prescribed by the maker at their recommended intervals. So if you delay replacing plugs and go for another 50K miles expect to replace items that wouldn’t normally need replacement. Coils and plug leads will be stressed to failure. Another issue is “upgrades” that are in fact downgrades. Factories aren’t leaving power or economy on the table in the ignition department.
fred cook 10-03-2019 02:19 AM
Before I changed to Electromotive XDi crankfire ignition, I used an MSD system for several years with no problems. I believe that the key is to find/use a proper plug wire set. I used a homemade set that used new Beru connectors and well insulated wires. With the XDi, I am using the Clewitt wires (dual plug) with no issues.
manbridge 74 10-03-2019 06:24 AM
To be clear I was speaking to the guy with the 2005 vehicle. Nothing wrong with a well installed MSD or the like but one interesting fact from Neil Harvey over in the engine rebuilding forum. He states the measured combustion pressure from the Bosch CDI system as the highest of all the ignition systems they tested. Not too bad for something that was introduced on road going 911s in 1969.
