-   -   Where can I get cadmium plated motor mount bolts for a 86 Carrera (http://forums.pelicanparts.com/porsche-911-technical-forum/1008096-where-can-i-get-cadmium-plated-motor-mount-bolts-86-carrera.html)
gomezoneill 09-17-2018 05:48 PM
Post say's it all.
cabmandone 09-17-2018 07:30 PM
Google says you can buy one from Pelican Parts
Part #: 900-082-142-01-OEM
gtc 09-18-2018 08:16 AM
You could have yours replated by Shaun.
gomezoneill 09-18-2018 08:49 AM
That bolt is zink not cad.
1979-930 09-18-2018 09:51 AM
Get the Caswell Plating kit and a small crock pot at WalMart. New Zink bolts can all be turned to Yellow in your garage.
https://www.caswellplating.com/yellow-chromate.html
Snitzler 09-18-2018 01:41 PM
I had the same problem. I got these bolts from Belmetric and they are yellow zinc. BTW, they are a little longer at 35mm but then you can use washers and a proper locking bolt rather than crap split washers.
http://forums.pelicanparts.com/uploa...1537303151.JPG
http://forums.pelicanparts.com/uploa...1537303151.jpg
gomezoneill 09-18-2018 03:12 PM
I'm good with the small bolts. I need the long bolts through the center.
