finally getting to it - brakes
i had posted a while ago about a sticking brake issue with my 1984 911 carrera convert. and the advice was locate and most likely rebuild caliper ---when i started thinking about how long ago this may have been serviced i started to think maybe replace everything in front. I was looking at this kit
https://www.pelicanparts.com/More_Info/PELFRBK911B.htm?pn=PEL-FRBK911-B&SVSVSI=579&DID=275272
and was also thinking about new hoses, and caliper rebuild kit as well - first is this kit ok and is there anything else I need for this job (besides fluid dot 4 i believe)
thanks very much
Sean
Old 10-05-2025, 02:01 PM
You will need a set of seals for the calipers if you are going to rebuild them. Something like this
https://www.pelicanparts.com/More_Info/91135194600.htm?pn=911-351-946-00-OEM
Old 10-05-2025, 02:13 PM
excellent - thanks added to my project list!!
Old 10-05-2025, 02:58 PM
