Clear Plastic Brake Lines
Hi all,
I've tried searching this forum and online and cannot seem to find anything on this subject. I have a 1970 911E and I want to replace the clear brake line tubing that runs from the brake fluid reservoir to the master cylinder.
Porsche part # 901 355 644 00
Has anyone replaced theirs and with what?
Regard
Chris
Old 09-19-2018, 10:15 AM
It seems Pelican does not sell those brake lines anymore.
The p/n you posted is not the brake line, it is only the tubing that goes into the master cylinder.
Some people use the blue brake hose to substitute the clear lines.
I assume you are talking about the lines in the diagram.
Old 09-19-2018, 01:20 PM
Correction Pelican sells these
https://www.pelicanparts.com/catalog/shopcart/101P/POR_101P_911052_pg1.htm
Old 09-19-2018, 01:32 PM
Yes, those are the lines I was referring to. Thanks for the link. Pelican shows clear and black tubing. I'll have to call but I think only black is available.
Old 09-20-2018, 04:42 AM
