-   -   cost for 3.4 twin plug conversion? (http://forums.pelicanparts.com/porsche-911-technical-forum/1008278-cost-3-4-twin-plug-conversion.html)
ourv12 09-19-2018 01:22 PM
Whats a ballpark figure to convert a 3.2 to a Mahle 3.4 twin plug complete setup including ignition signal splitter ?
Trakrat 09-19-2018 01:32 PM
I looked into this recently, and came up with needing the following:
twin distributor
heads and valve covers machined for twin plug
6 extra plug wires
ignition control unit
custom chip
I stopped when I found a twin plug distributor for ~$2500
darrin 09-19-2018 02:56 PM
you might want to contact sal carceller (scarceller on pelican) - he's reverse engineered the andial splitter electronics, can program the right chips and has experience from doing a number of these for other. Seems the real question here is what is the delta between a traditional rebuild/top end (or single plug 3.4 setup) and a dual plug 3.4 -- also, you might want to look into going up to 3.5 -- if buying p&c either way, the $ bump isn't that high to get the case spigots machined and, since a 3.4 is just under 3.4 liters and a 3.5 is just over 3.5 liters, there's a fair bit of potential to be had. Also, not sure where the $2500 distributor cost is coming from, 964 setups run around $1k used and there are other options available as well
RSS 09-19-2018 03:21 PM
There are other options out there other than the Andial splitter. The splitter does just that, splits the spark. It is very weak. I used 2 Crane HI 6 ignitions on my 993.
rbogh901 09-19-2018 08:12 PM
What are the reasons more people don't do the 964 993 twin distributor conversions? And please describe what is involved in using one of those. I think many people did that in the past but the details have been few and far between. It looks cost effective but you don't get a 12 plug distributor cap along with its bragging rights.
Raceboy 09-20-2018 12:33 AM
Cheapest version is obviously using two 3x2 Bosch coilpacks (~100 usd each) and MS or VEMS standalone. Those would cost around 1000 euros, VEMS comes with a running map.
