Multimeter Recommendations
Hi All, I need to purchase a quality multimeter to track down a few ignition gremlins. I’m far from an electrical expert, so simplicity and functionality is what I’m looking for. Does anyone have any recommendations?
Thanks in advance.
Old 09-22-2018, 04:52 AM
PCA7GGR's Avatar
Get a HorrorFrieight one - free with coupon. Has all the basic functions and is accurate enough for th basic stuff. I carry one in each car.
Sergio
The GT Lid Whisperer
PCA 42yrs - National DE Instructor / Ex-RGruppe #197
'19 718 Cayman S (9th Porsche/1st with PDK)
'14 Subaru Forester XT (Porsche support vehicle)
Old 09-22-2018, 05:05 AM
old man neri's Avatar
I ended up getting a Power Probe III. Expensive but it has been nice to use. It's more than a multimeter.
As for a regular multimeter. There are millions out there. I certainly wouldn't get the most expensive and I wouldn't get the absolute cheapest either. They will all do what you need to do for car work. 1) check for voltage, 2) check for resistance/continuity.
Old 09-22-2018, 05:07 AM
Look at the ranges for the functions you will be using. For example, some of the cheaper units only have one or two resistances settings (ohms). But, I use these settings a lot to check the resistance of many different components (plug wires, sensors, etc.) so my most recent multi-meter has five different resistance ranges. Also, be sure that there are plenty of voltage ranges for everything that you will be testing.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 09-22-2018, 05:26 AM
Dr J's Avatar
This is actually not a bad idea. I do the same and it covers the basics. It just depends on what you want in the multimeter. The HF one does all the basics.
If you are thinking of future possible uses beyond the scope of the present project you need to ask: Do I want temperature measurement as well? Frequency measurement? High amps? Computer interface? Waveforms? All can be had for a higher price.
In addition to the HF I have owned an Omega HHM 590 for many years. Because of my engineering background I often need more than the basic MM. For that I use the Omega HHM590.
https://www.omega.com/pptst/HHM590.html
If you want a MM from a company with solid reputation check out Fluke.
Finally, for looking at changing signals, an analog multimeter is more useful than watching a bunch of numbers continually changing in a digital MM.
With all that said, for a basic project the HF should work fine.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 09-22-2018, 05:32 AM
sugarwood's Avatar
You can get a digital one for $10
1986 Bosch Icon Wipers coupe.
Old 09-22-2018, 05:43 AM
Possibly more important are the test leads. Get a good assortment to back probe connectors, alligator clips, etc. I have heard good things about the power probe. I’d get that if I did all over. Plus the name is *****’n.
Old 09-22-2018, 09:56 AM
radio shack has,or used to have a very compact foldable one with the basic functions. I got 3 and all have lasted well. affordable too
80SC (ex California)
Old 09-22-2018, 10:24 AM
I have a Fluke 88 automotive meter but usually end up grabbing the free Harbor Freight MM to do a quick test so I don't have to open the case & attach leads to the Fluke. When I want to be sure about a reading, I'll use the Fluke. May want to think of a gently used one from Fleabay if you want to go quality without breaking the bank.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 09-22-2018, 10:32 AM
Ronbo's Avatar
I have one of these too. It seems accurate enough and you can't beat the price.
Ron
'88 Coupe (formerly)
Old 09-22-2018, 10:39 AM
put one in the glove compartment !
https://www.radioshack.com/products/radioshack-22-range-pocket-digital-multimeter
Old 09-22-2018, 11:08 AM
Thanks to everyone for the input. I actually have a Harbor Freight freebie that I have used in the past. I do like the idea of keeping one in the glovebox or the frunk. It seems as these cars age, the electrical system becomes more problematic. I’ve had a couple of issues with CDI boxes and coils this summer. Thought it would be time to get a simple yet reliable meter to keep in the garage for testing anything that would be necessary in an air cooled car. I do like the idea of alligator clips on a set of leads. Maybe something that has an audible for continuity as well as a reading? What things should I be looking for in a meter to make it easy to use? Decent quality. Thanks.
Old 09-22-2018, 12:36 PM
I am constantly using a multimeter. Between my old houses wiring, building tube amplifiers, fixing espresso machines as part of my job, air conditioning repair, etc. I need them. I have one in the glove compartment of all my cars, bench multimeters in the house and garage, I am always needing to use one. I've a ton of rechargable 9v batteries also, use them for guitar pedals also.
I was told a long time ago that if you don't buy a Fluke, you will soon. Drop into any pawnshop, they will have five or more to pick from, usually around 40-80 . They are good tools, you will be surprised at how often they come in handy. And a Fluke is reliable, accurate, durable.. And, while you are at it, buy a soldering iron, they go hand in hand.
Old 09-22-2018, 02:25 PM
Consider getting one with direct DC amps measurement, the higher AMPs the better.
Sold: 1989 3.2 coupe, 112k miles
Old 09-22-2018, 04:28 PM
Anyone who can build a tube amplifier knows what they're talking about. I'd follow Ed's advice & get something (even if used) with quality.
Written in the glow of my McIntosh 240 tube amp.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 09-24-2018, 06:19 AM
Platinum Member
dad911's Avatar
This. Clamp on DC amps, so you can measure battery drain, charging current, etc.
Most clamp-on meters are AC only, you have to check specs to make sure it's DC.
Old 09-24-2018, 06:26 AM
Pelican Parts Vendor
UROParts's Avatar
Our engineers use Fluke, but the price is definitely right to carry one of those HF units in each car, too bad they don't have a continuity tone. They probably leave out a feature or two to help sell the next best model.
Old 09-24-2018, 07:42 AM
kevingross's Avatar
Fluke.
Kevin
Catellus Engineering
catelluseng@gmail.com
http://www.catellusengineering.com
https://www.facebook.com/catelluseng/
Old 09-24-2018, 10:09 AM
85911's Avatar
I see quite a few references to a free HF meter wit a coupon. How do you get the coupon? I went to their website and didn't see one. Does it only come out once in awhile?
Thanks.
1985 911 Carrera Targa, 2011 911 Carrera S 997.2, 1951 Harley Davidson Panhead Chopper, 1957 Harley Davidson Panhead- stock, 1972 Yamaha 250 DT-1(sold), 1959 Austin Healey (Bug Eye) Sprite- sold, 1959 Austin Healey (Bug Eye) Sprite- sold, 1960 Austin Healey (Bug Eye) Sprite- sold
Old 09-24-2018, 11:31 AM
here you have
https://www.hfqpdb.com/best_coupon/7+FUNCTION+DIGITAL+MULTIMETER
Old 09-24-2018, 12:32 PM
