-   -   86 930 No Spark (http://forums.pelicanparts.com/porsche-911-technical-forum/1008639-86-930-no-spark.html)
kupcar 09-23-2018 02:22 PM
86 930 No Spark
Hi All, I went for an evening drive the other night and my car left me stranded. Cruising along at a constant 50 mph, the motor shut down. Almost like the key was turned off. On the side of the road, the car cranked but wouldn’t start. After getting it back home, I’ve determined that we have a no spark issue. I can hear the Bosch cdi box whine. So I thought that the box was ok, or at least getting power. I then switched the coil with a known working spare. Still no spark. I haven’t tested the green distributor wire, and not quite sure how to test, but the wire looks clean and connected. My question is what to do next? Are there any simple tests to do to determine if the cdi box is the issue or should it be sent out for a pro to bench test it? If sending it out, any recommendations?its a standard 6 pin Bosch. Thanks.
Jonny H 09-23-2018 02:32 PM
Discussed a million times on here, do a search.
kupcar 09-23-2018 02:45 PM
Thanks Jonny, I have. I’ve read in my search that you’re a developer of one of the replacement products available. How would you address this problem? Another question for you, what do you offer in the 8 pin option, or is their an adapter plug available to use a 6 pin.
john walker's workshop 09-23-2018 03:08 PM
2 of the 8 pin wires go to a condenser mounted on top of the rear panel. Delete that and rearrange the 6 wires into a new 6 pin plastic plug.
kupcar 09-23-2018 03:42 PM
Thanks John. The car with the 8 pin setup is a 76 930. I’ll have to take a closer look at the condenser that you are referring to. I’m a bit challenged when it comes to the electrical system. Always learning. I appreciate your time and help.
john walker's workshop 09-23-2018 07:18 PM
Did that on my 77 930.
timmy2 09-23-2018 08:01 PM
They only use 7 of the 8 slots and that was just to split a ground that they tied together in 78.
Jonny H 09-23-2018 11:14 PM
Unfortunately, the 6 pin boxes will NOT drive the early Turbo tacho. The drive signal is unique to this tacho (and the race car tachos)
We have a complete 8 pin replica CDI+ unit available now.
T77911S 09-24-2018 02:44 AM
at the connector for the cd unit 7you can ohm the 2 wires going to the DIST. should be around 600 ohms f I remember correctly.
