Replacing glass in 83-86 door mirror
A while ago I broke the glass in my driver's door mirror on my 86 Targa. Dumb move on my part; I was backing into a tight space. Anyway, I bought a replacement mirror glass from Pelican and now looking at how to change it. Unfortunately, my Bentley manual for the Carrera only provides detail for the replacement of the 87-89 mirror glass. As the mirror is supposed to be the same for the 1983 through the 1986 cars, I wonder if the 911 SC manual details how to change the mirror glass for this particular mirror? Can someone with a 911 SC manual have a look?
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 09-23-2018, 01:17 PM
I have an 86 coupe. I believe the glass should just pry apart from the base. Its held in by three tabs.
Move the glass to it's outer most position and pry.
Then the the inner most, and pry.
Doing this all around the glass.
Old 09-23-2018, 01:59 PM
Cars and Cappuccino
tdw28210's Avatar
Carefully heat the glass with a heat gun or hair drier to soften the glue and pry with plastic bars from Harbor Freight.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 09-23-2018, 04:12 PM
Thanks, Steve. I pried very carefully and the broken mirror just came out. You're correct. There are three nubs that push into sockets. Not sure that heating it would have made any difference as it isn't held in by adhesive. Now to install the new glass and forget that it happened!!
1990 964 Coupe
Old 09-23-2018, 04:39 PM
Cars and Cappuccino
tdw28210's Avatar
I've had adhesive on two mirrors. Maybe they were both redo's?
Old 09-23-2018, 04:46 PM
RedCoupe,
happy it worked out.
Old 09-23-2018, 06:02 PM
