daltvater's Avatar
Identify this Flange??
Help!
Had a drive shaft come free and I messed up this flange. I'm over in New Zealand and for the life of us we cannot figure out this part number.
The car it is off is a 1979, with a 915 gearbox attached to a 3.6l. The car is a Frankenstein of parts.
I can't make out the part number on the flange, the diameter of the shaft before the spline is 35mm, M10 bolts and the OD is 110mm.
As for the part number. Hell if I can make it out. These part numbers are a best guess but almost none of the numbers can really be made out.
975 337 709 01
Or
975 387 709 01
Old 09-25-2018, 02:51 PM
It’s a course spline with 10mm bolts. Course spline is pre SC
10mm bolts were used in the early 70s with two roll pins and 4 bolts.
I’ll edit if I see in PET
BRUCE
The 72 / 73. Used four bolts and two roll pins
Old 09-25-2018, 04:30 PM
Originally Posted by daltvater View Post
I can't make out the part number on the flange, the diameter of the shaft before the spline is 35mm, M10 bolts and the OD is 110mm...
975 337 709 01...Or...975 387 709 01
It appears to be an early 4-bolt, 2-pin 915 flange modified to have 6 M10 bolt bores.
The number is probably 915 332 209 01.
Jon B.
Vista, CA
Old 09-25-2018, 04:34 PM
daltvater's Avatar
BRUCE
Damn you guys are good. New Zealanders are crafty people and make what they have laying around work. No wonder I ordered the wrong replacement part.
Thanks for the help guys, Dan
Old 09-25-2018, 09:52 PM
Under the radar
Trackrash's Avatar
That number is good. Here is my old '72 drive flange. I'm not sure how to best modify the hole for the roll pin to accept a 10mm thread. Any ideas on that?
Gordon
'71 911 Coupe 3,0L outlawed
Old 09-26-2018, 10:38 AM
