911 Ignition Switch Terminal Connection Mapping
would anyone out there be able to, or already have, mapped the female terminal connection to the ignition switch,, (I know someone had already done this with a nice picture but after much searching I can't find the thread)
Thanks !! http://forums.pelicanparts.com/uploa...1537818019.jpg |
30 is +12V battery always hot. (supply to the switch, will connect to the other pins based on ignition position)
15 is +12V with ignition in Run and Start positions 50 is +12V to starter in Start position R is +12V to radio in Acc position X is +12V in Acc and Run position P is +12V with ignitinon Off position |
Here you go....good luckhttp://forums.pelicanparts.com/uploa...1537997335.jpg
http://forums.pelicanparts.com/porsche-911-technical-forum/430286-problem-ignition-switch-wires.html |
| All times are GMT -8. The time now is 01:11 PM. |
