![]() I am starting to get requests for Hose replacements of this 3.2 Carrera Fuel Return Line..... ![]() This is crimped from the factory, and anyone who has a leak with this hose has to replace it with a new assembly or make a temporary repair with hose clamps. I have just received an original that is leaking, and will make up a E-85 Rated Replacement Hose that will be crimped in place. The return lines are less likely to leak as the pressures are somewhat lower than the Feed. If and when this does leak, I offer an inexpensive solution. Of course, postage will not be cheap or easy to send, but that is another matter. At some point, if there is enough need, I will offer this on an exchange basis. For Info please email me: Len dot Cummings at verizon dot net
BoxsterGT,
I sent an email to len.cummings@virizon.com in hopes you can assist in replace my fuel lines; front, rear, and Polyamid tunnel lines. Your message box on the forum is full. |
![]() reefdiver- It is: v e r i z o n dot n e t Len
Thanks, I resent the message.
Len,
I'm attempting to re-contact you to ensure you can fill the tunnel fuel line and pressure/return line order before I send you a money order. Please let me know how to proceed. |
![]() ![]() ![]() Len, Understand your busy with your move. Was worried something may have happened. If you have the items pictured above let me know. Ill get the engine lines somewhere else. |
![]() Got it and replied. Thank you. Len
