-   -   Hardware list available? Nuts bolts washer shopping list for engine etc (http://forums.pelicanparts.com/porsche-911-technical-forum/1008847-hardware-list-available-nuts-bolts-washer-shopping-list-engine-etc.html)
rxtrom 09-26-2018 08:27 AM
Good morning.
I am looking to get some newer plated hardware for my engine rebuild and other various locations around the car. I am not looking for concourse replacements for period correct supplier/year. I am just looking for a shopping list of bolt nut washer sizes/type for an order on Belmetric for example.
I have looked at the PET but the information is scattered, if someone has a list they could share that would be terrific.
As a side note I saw the kits on Pelican but the reviews were suspect.
Thanks in advance.
Rob
DRACO A5OG 09-26-2018 08:52 AM
Mag case or Aluminum?
What ever you get, get the Wrightwood seal kit, everything is there but when it comes to the chain cover make sure the washers are SS as the aluminum ones are worthless and will squash.
Also for the engine halves I suggest the all metal lock nuts
Use ARP rod bolts/nuts and consider CP Carrillo Pistons or Mahles.
Side note, make sure crank shaft is to spec after polishing and straight, case journals are straight and replace oil squirters. Get Porsche Bearings or several OEM but you must measure them to insure they are uniform or place in order of wear on the crank.
Break a leg Brother!
rxtrom 09-26-2018 09:37 AM
Thank you for the tips. I have most everything covered on your list but I am just looking for the hardware list regarding sizes of the bolts, nuts washers etc..
Something like this but with the details of the inclusions so I can order from a site like Belmetric
https://www.pelicanparts.com/cgi-bin/ksearch/pel_search_2016.cgi?command=show_part_page&make=PO R&model=911M&section=engreb&page=1&bookmark=2&part _number=PEL-REBKT-06
Marc Bixen 09-26-2018 10:20 AM
Just have all your stuff replated when the parts are at the machine shop. Gold or yellow Cad plating. Most platers charge "by the lot". Average cost in So. Cal is about $80. Send them everything, throttle linkages, clamps, brackets etc. You'll be looking concourse in no time. We also always throw in some extra.
Peter Zimmermann 09-26-2018 12:23 PM
What Marc said is right on. Also, if you have bolts/nuts in non-repairable condition, replace then with like sizes, found at a variety of businesses found on Google, and include them with your re-plate order. That way what you must replace will match the rest of your hardware.
Uwon 09-27-2018 04:37 AM
+RS O-rings for the rocker pins.
LN Engineering offer some good pistons,rings, etc. as well as piston/cylinder and top end refurbishing services. Talk to Charles.
Wurth has an excellent assortment of yellow zinc nuts and bolts. In Canada they deliver; not sure about the US.
Good luck. Exilerating project.
Johan
SalParadise 09-27-2018 09:58 AM
I've never had any luck with plating - even in California. It's pretty much suspect and wears very quickly.
I would replace all hardware from BelMetric. I pretty much used all their stuff on my car and it looks great. No hassle, and it's pretty inexpensive. They ship the same day and it's awesome.
rxtrom 09-27-2018 11:56 AM
Sal this is exactly what I am looking for. DO you have a prior shopping list or something you can send me? I will PM you my email.
Thanks.
VFR750 09-28-2018 03:28 AM
Doesn’t pelican offer the fastener “super kit”?
I bought one for my rebuild several years ago. Just what I needed and at a resonable price considering the amazing number of nuts and bolts needed to put this engine back together.
gtc 09-28-2018 11:45 AM
I bought some clear plastic organizer cases from harbor freight and filled them with a selection of yellow zinc hardware from Fastenal and other hardware stores. They are also good for organizing hardware during your engine teardown.
You can save a fair amount of money compared to the hardware kits from Belmetric or Pelican.
