MFI cold start solenoid amps
Hi all,
I'm replacing a manual cold start enrichment switch on my 1970 911E with a timed relay and wondered if a 10A relay would be sufficient. I believe there is an inductive load which may require a hefty relay? Any idea what amp rating the original "black" relays are?
thanks, Derek
Old 10-19-2018, 05:18 AM
356RS's Avatar
A 10 amp relay would be fine. The solenoid draws less that 5 amps.
Mark Jung
Bend, OR
MFI Werks.com
Old 10-19-2018, 06:48 AM
Thanks Mark!
Old 10-19-2018, 12:54 PM
Why not put in a manual push button on the dash to manually start the MFI system. I have had this in my 2.7 1973 for almost 20- years and it works great.
The button supplies ground to the relay that actuates the solenoid.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 10-19-2018, 01:16 PM
As I said above "I'm replacing a manual cold start enrichment switch on my 1970 911E with a timed relay." I prefer a small timed relay to the manual switch.
Old 10-20-2018, 04:15 AM
I prefer to know what it is doing by......doing it myself.......I went through the "timed relay" waste of time.
I have a push button on the dash hooked to a relay that activates the fuel solenoid on top of the filter.
Starting is like using a "tickler" on one of my old motorcycles.
I also removed the cold start bi-metallic stack and installed an adjustment knob. Makes for good fine tuning on the run.
I do have a permanently installed AFR instrument. A good one made by Daytona Sensors and available from Pellican. I know all the time where my AFR is reading. I can make minor adjustments with the adjustment knob.
I have been running my 2.7 for almost 10 years with this setup.
03 Boxster
Old 10-23-2018, 01:08 PM
