-   -   2.7 Sitting for 4 months, Q&A prior to trying to start it (http://forums.pelicanparts.com/porsche-911-technical-forum/100919-2-7-sitting-4-months-q-prior-trying-start.html)
chumphries 03-06-2003 12:46 PM
My 77 2.7S has sat over the last four months unfortunately due to other priorities (gotta eat and pay the mortgage :)
I'm ready to start working on her again (she's been runing fine prior to garaging). and was wondering what steps anyone would recommend for a car that's been sitting four months prior to restarting it?
Thanks for any and all help!
Tim Walsh 03-06-2003 12:52 PM
where has it been sitting? If it's anywhere near where rodents can get in, you really need to inspect the cooling fins. Mine were covered in leaves.
Someone with more expertise can tell you more but 4 months isn't too bad. Mine sat for 2 years.
agabriel 03-06-2003 12:56 PM
My '86 was in the garage for 3 1/2 months until last weekend. I checked the oil - looked underneeth for puddles. Then started it up. After a few minutes warm up drove it for the day. I had a great time to :)
Have fun!
Anthony
chumphries 03-06-2003 01:00 PM
The car has been garage kept (my garage) in a mostly non-damp environment. It hasn't been exposed to the elements at all sans the cold temperatures garages get to.
Joe Bob 03-06-2003 01:46 PM
Spin it with the coil wire to the dizzy disconnected....it will get oil to the dry areas.....then start it.
chumphries 03-06-2003 01:50 PM
I'm going to come of sounding very unintelligent here but could you elaborate what you just said a little more? I'm not familiar with really any abbreviations you used. :(
Thanks for the advice, here's hoping I learn something in the process :)
jmohn 03-06-2003 01:56 PM
Just check the fluids and start it. Four months is nothing.
Jerry M
'78 SC
ischmitz 03-06-2003 01:56 PM
dizzy = distributor
If you disconnect the cable going from the ignition coil to the distributor the engine will not start but turn over. It'll allow it to build up some oil pressure and lubricate dry areas. Just crank it a couple of times for 10 seconds each.
Ingo
Adam 03-06-2003 02:04 PM
That's probably all that's needed. I plan on doing this this weekend, as my 2.7 has sat around for about 6 weeks.
chumphries 03-06-2003 02:06 PM
Thanks for the help! I'll give it a go and let you know how it turns out!
tryan 03-06-2003 04:16 PM
be gentle until the moisture gets cooked out of the oil.
Loual 03-06-2003 05:04 PM
Just fire it up!
I agree; four months is no big deal if it's been in a garage. I've done that numerous times over the 20 years I've had my 2.7.
