Driver side window rattle
Hi everyone! As the cold weather rolled in I started hearing a rattle in my 88 911 Targa coming from behind the driver side door window. I was able to reproduce by shaking the window manually (if I do the same on the passenger side it doesn’t do it). See video here:
https://youtu.be/8BwInD3XnHs
I did some research in the forum and found the following threads:
Drivers side window rattling
911 electric window rattle -- the fix!
Do you guys think this is related or something else?
Thanks!
Old 10-21-2018, 10:03 AM
Update: did a quick inspection by removing the panel but everything was very tight. I also checked and can confirm that the noise only happens when all the way up. That wasn’t what I experienced during driving (as it would make that rattling noise with window all the way up, middle or completely down).
Any ideas?
Old 10-21-2018, 07:29 PM
