Chain fence eating turbo
I can tune my 911 to stoch (14.7) with fully programmable EFI, but it doesn't like it at all.
13.5-14.0 is about as lean as the engine likes.
Get down in the 12's, and it really wakes up torque wise.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR P & C's, soon to be 993SS cams and GSXR 750 ITB's fed by 964 intake, Borg-Warner S366 turbo @ 1.4 bar, Treadstone full bay IC, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MegaSquirt 2 (v3.57 board) w/EDIS, Tramont wheels (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 10-10-2018, 11:35 AM
Under the radar
Trackrash's Avatar
Location: Sebastopol, the land of wine and redwoods in The Republic of California.
Originally Posted by Porsche 2 View Post
My engine is running well at all speeds, except for an occasional small hesitation when accelerating vigorously from idle, after changing from 60's to 55's idle jets. This change has helped increase idle A/F's from 10.4 to 11 at 800rpm. My idle air adjustment screws are several turns open, and air/fuel mixture screws are turned out only 1/4 turn.
So I am continuing trials and researching options to; 1) eliminate the occasional small hesitation when accelerating from idle, and 2) increasing the idle A/F ratio into the 12 to 13 range.
1) I am waiting for a set of "Hatchet" carb acceleration fuel pump cams, and a set of 175 air correction jets to replace the 180's installed, to address acceleration hesitation.
2) I have a range of idle jet sizes and have discovered that the idle jets that are 55's, 60's, or 65's (maybe even smaller and larger sizes) all have the same diameter side air inlet holes, that introduce air into the idle jet metered fuel, with this emulsified fuel mixture descending to the air/fuel mixture screws that control the volume of this fuel mixture into the carb throats. Thus, I conclude that if I replace the 55's in my carbs with 50's and open up the air /fuel mixture screws to regain lean best idle, this may result in a higher A/F ratio at idle.
Comments?
Weird you are rich at idle with 55 idles. That combined with you only having the idle mixture screws out 1/4 turn makes me thing something is wrong. Perhaps the floats are too high? Also I have read you should start with the bypass screws all the way in.
Gordon
'71 911 Coupe 3,0L outlawed
Old 10-10-2018, 01:22 PM
I have recently reset the float levels to the middle of the gauge level marks - probably not my issue, but thanks for your response.
I see that I missed clarifying my discovery and conclusion on the idle jet hole diameters. I am suggesting that given all three jet sizes have the same side air entry hole diameters, I am concluding that the smaller jets with smaller fuel entry hole diameters result in a leaner emulsified mix of air and fuel delivered to the air fuel adjustment screws, leading to a leaner (higher) A/F reading(?).
Old 10-10-2018, 01:44 PM
Under the radar
Trackrash's Avatar
True.
But I still can't believe you only have your mixture screws out 1/4 turn. My thought is somehow extra fuel is getting through to lower your AF ratio.
Gordon
Old 10-10-2018, 02:12 PM
VFR750's Avatar
If the idle screws were tightened too much, the tip of the screw can get little trough cut into it. Effectively ruining the ability to meter the flow. They become very non-linear. They are closed, then, with a little bit of rotation, they flow a large amount.
Your idle air screws should only be used to balance the three throats when you use the airflow meter.
If you are very rich with 55s or 60s then the idle air correction jets might be too small.
I have zeniths, but I run 60 left/62 right idle jets with 135 idle air correction jets.
Old 10-10-2018, 06:55 PM
VFR750, thanks for your comments - yes it seems logical to me that the idle air jets are too small, as there is almost no change in A/F's when reducing the idle jets from 60's to 55's, which is actually a significant reduction in jet cross sectional area, about 14%. Thus I am considering drilling these air jets out a little. The air jet holes are close to 1.3mm in diameter. What increase in diameter does anyone suggest?
Old 10-11-2018, 11:39 AM
1QuickS's Avatar
Apparently you have IDTP Webers and not IDAs (IDAP, IDT or IDS). IDTPs have 1.40mm bleed hole diameter while all of the others have 1.10mm bleed hole diameter.
IDTP Webers partially expose first progression hole at idle which adds fuel to what the mixture screw provides.
IDTP Webers have mixture screws with a needle tip vs. a constantly tapering needle; an IDTP screw is the mixture screw to the right in the picture while IDA Webers use the middle one. The left needle has a steeper taper than IDA screws which would provide a more rapid change in mixture than the IDA needle.
All of the triple throat Webers use 1.0mm dia transfer holes in the throttle housing to meter fuel through.
If you have a brass mixture screw (by PMO) then it is quite possible to have a ridge in it from over-tightening but the Weber screws are of steel and the grooving is not quite as likely.
The sealing cup washers can effectively prevent the mixture screws from sealing the transfer hole which is due to tolerance stack-up issues. If you cannot definitely stop fuel flow by closing the mixture screw and you have the cup washer with o-ring I recommend removal.
Depending upon venturi size in your Webers the air bleed will rather dramatically lean transition mixture so I recommend caution in this approach of drilling to larger size. Venturis larger than 30mm are susceptible to this issue.
Air flow balance should be somewhere close to 5 using STE synchrometer. I recommend using this tool since other tools only provide air flow parity which means you could have idle air balance at higher air flow which would indicate rich idle mixture due to excessive idle air flow requiring more fuel to support combustion.
If the needle tip of the IDTP screw is broken off or if you have mixture screws with tips that are around 1.0mm or larger then a minute adjustment of the mixture screws will completely open the 1.0mm dia transfer port.
Old 10-11-2018, 12:32 PM
I measured the orifice of the idle jet with my old vernier scale micrometer - not good enough, i believe they are actually stock 1.1mm. And I checked again, my carbs are 40IDA's. I am now in email contact with Paul Abbott, and have decided to pass on drilling these air jets. I am going to find some "hatchet" accelerator pump cams and check the check valves at he bottom of the float chambers to reduce/eliminate the slight acceleration hesitation when accelerating from low rpm's. Will also stay with the 55 idle's.
Thanks for your input.
Old 10-11-2018, 02:03 PM
Update.
Installing "hatchet" shaped accelerator pump cams has solved the hesitation in acceleration issue
I have today replaced the 55's with 50's idle jets and this has increased the idle A/F's from 10.3 to 11.5 at 800 rpm's - a good improvement. A test drive and seat-of-the-pants judgement, there is no noticable change in power in the midrange mode with no change in WOT mode. Will stay with this set up and see what miles per gallon I get.
Old 10-15-2018, 02:51 PM
devalued member
juanbenae's Avatar
Update.
did you get them from PMO or else where?
75S slick-lid webered, early n spicy 3.oL hotrod wanna be
07.5 2500HD GM Diesel 4x/93 tuff-gong 4.oL YJ Wrangler
08 DRZ400SM+FCR Mikuni
78SC PRC Spec911(sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ
Old 10-15-2018, 03:11 PM
From Paul Abbott.
Old 10-16-2018, 07:32 AM
From Paul Abbott.
not all heroes wear capes.
(though I've never met Paul in person so he might wear capes around who knows)
youtube.com/bennyobscene
Old 10-16-2018, 07:55 AM
kent olsen's Avatar
Paul Abbott is an awesome fellow. He helped me fine tune my webers and is a wealth of knowledge.. My west coast weber expert. He's now in Oregon.
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
RGRUPPE #104
Old 10-16-2018, 09:21 AM
1QuickS's Avatar
Aw, shucks...Thank you to all!
Old 10-16-2018, 11:14 AM
devalued member
juanbenae's Avatar
P2, any improvement post hatchet install if in fact you got them implemented? I just got my set in the mail yesterday but likely won't get to installing them for a week or so.
regarding Paul? not enough can be said about his information on these carbs at his site. I have run carbs, both PMO's and webers previously that were both dyno tuned by others and never had any issues or problems. upon building my current motor and setting a set of weber 40's on it I was having all kinds of issues getting them set up well.
if not for paul I would have thrown my arms up and a ton of money at somebody to get them sorted out im pretty sure. instead I followed his trouble shooting charts, made the hands on changes/adjustments and more often not got the results he suggested I might see learning a ton along the way. im confident dyno turning could squeeze a bit more out of it, but im pretty happy with where I was and where it is now thanks to paul.
thank you sir paul….. or did a beetle already have that handle?
Old 10-28-2018, 03:33 PM
1QuickS's Avatar
Thanks again.
I always feel a little uncomfortable with making carb tuning suggestions since I came to this profession as a mechanical engineer some years ago as opposed to having spent my life in the trenches with carbs. I believe: "Sometimes the magic works" when there are positive results from my input. (Quote from "Little Big Man".)
Paul's knighthood is safe from me.
Old 10-28-2018, 07:14 PM
Gordo2's Avatar
Late
Originally Posted by juanbenae View Post
im confident dyno turning could squeeze a bit more out of it, but im pretty happy with where I was and where it is now thanks to paul...
Late to the conversation - and realized Mr. Abbott had chimed in, and as such there wasn't much I could add.
With regard to the original post and issue - I was thinking Mr. Abbott makes a Weber modification to allow you to swap out the idle/progression circuit air correctors. PMO carbs have swappable idle air correctors - standard Weber carbs don't from what I understand. I modified my PMO idle air correctors, which combined with the "hatchets" greatly improved my lower RPM AFR.
Quick comment for "juanbenea" - I've dyno'd my car / engine. It verified my AFR readings from the wideband and my jetting was good to go. My primary interest in the dyno was to adjust my XDi to optimize ignition settings. You can get pretty close to optimal with a wideband ("optimal" as far as carbs go), but if you want to optimize an ignition - dyno is really the go-to tool.
Good discussion - good luck,
Gordo
Don Gordon "Gordo"
'83 911SC Targa
'87 FJ-60 TLC
Old 10-28-2018, 08:09 PM
I installed the "hatchet" cams on the carb accelerator pump linkages - hesitation is eliminated!! Also installed 50's idle jets - too lean. Back to 55's and engine is running smoothly under all rpm's and varying power ranges.
A/F's still at 10.5 at idle at 800 rpm Have ordered a set of metric jet reamers - two weeks delivery. Will then ream out the small pressed in idle air jets 0.1 mm and report back.
Old 10-28-2018, 10:38 PM
devalued member
juanbenae's Avatar
my AF remain in the mid 10's at idle as well, although I do run my idle a bit higher at around 1k. I raised from about where you are and did see some improvement with the higher idle.
look forward to getting mine installed, in fact the fix up of the house for sale may be back burned for a day this week..
Old 10-29-2018, 09:06 AM
1QuickS's Avatar
My personal experience had me accepting an idle AFR of around 10.5, this was after tweeking idle air correction & idle jets plus cam levers.
Cam levers squirt extra fuel for sudden throttle opening. I recommend a test procedure where you slowly accelerate up slight incline to check for the engine's ability to take mixture. I recommend 2nd gear as well, it will modulate throttle inputs better than using first gear.
An old-school method is to park the car & use the throttle stops to elevate engine RPM & look to see how your AFR readings change with RPM. Of course you will need to drive it & probably richen mixture after this parked test procedure.
Camshaft profile, compression ratio & other variables will affect engine's ability to run at leaner mixtures. An S-cammed engine with lots of overlap will need different jetting from a similar displacement engine with SC-cams with zero overlap and low compression.
My engine was a 2.3 liter with 10.1:1 compression & straight through exhaust and twin plug ignition. The main circuit used tall auxiliary venturis, F3 emulsion tubes, 150 main air correction jets and 35mm venturis in 43mm throttle bores. Idle jets were 52 & idle air bleeds were 90. Lots of inter-related bits and that should indicate that I worked on my jetting quite a bit and ended up with 10.5 AFR at idle as my best setup. If you look at the main circuit jetting you will see that all efforts were used to keep transition interface AND top end mixture strength as well.
Certainly, each engine will want to be tweeked for optimum setup and I am definitely interested in your results and notes of your efforts along this path. The nice thing about having tuneable idle air bleeds is that you can purposely overshoot your jet size as a way to put boundaries on your testing and then focus on solutions within that range of jet selections.
One last thought: Keep a detailed notebook of jetting selections, AFR readings vs. RPM and comments. Carbs are not the same as a programmable computer controlling your fuel delivery and ignition advance relative to throttle opening & RPM.
Old 10-29-2018, 10:15 AM
