-   -   swapping back - 912E conversion to stock (http://forums.pelicanparts.com/porsche-911-technical-forum/1009647-swapping-back-912e-conversion-stock.html)
Nditiz1 10-06-2018 05:03 AM
So my 77 Targa was converted to a 912E. It is running all the 912E bits, 923/02 Tranny, special rear sway bar and mounting block (welded mounts). The 914 is fine, but I want a 6 back in the car. I am trying to decide if I need to remove the 923 transmission to get everything to work properly or I can mate the 2.7 (or 3.0) up to it and have gear ratios like the 73 RS. Help me out Guru's what things will I need / watch out for if leaving the 923/02 in my 77. Thanks!
uwanna 10-06-2018 09:55 AM
I remember reading that the 923/02 will not work with a 6cyl motor.
Seemed to be a problem with the 923 mainshaft not being compatible
with the 6cyl motor. Can't recall the exact problem, perhaps someone
with better knowledge will reply.
Nditiz1 10-06-2018 11:49 AM
I am hoping it is only a matter of the correct clutch package. Didn't early cars mate to the rough splines? 70-73?
inaminit 10-06-2018 04:23 PM
I think if you can keep the current clutch parts, it will work. But this is a weak work around. You will be happier with a 915.
Matt Monson 10-06-2018 04:31 PM
Rubbish. There's nothing weak about it. The input shaft is splined like a 914 and requires the esrlier clutch stuff. Internally it is a 915 gearbox.
Trackrash 10-06-2018 05:17 PM
What you mean is the '70-'71 disk?
Nditiz1 10-06-2018 06:22 PM
Ok so if i get a 70 - 71 clutch disk package it will bolt up to a 2.7/3.0 flywheel and everything will be good.
Is there anything needed for mounting that may be different? Engine and transmission mounts.
Matt Monson 10-06-2018 06:28 PM
No, I said what I meant. The 912E's 923 gearbox uses the same 215mm clutch assembly that a 914 or 1969 901 uses. It does NOT use the 225mm 70-71 911 gearbox style clutch assembly.
As long as someone uses one of the 6 bolt 911 engines everything in the car can be retained when swapping the car back. That's part of why you see so many 914-6 conversions using the 2.7. It's fairly straight forward on the clutch piece of it, whereas the later 3.0 and up engines have a different crankshaft bolt pattern.
Nditiz1 10-06-2018 07:00 PM
Now I understand.
Thanks a lot Matt!
Trackrash 10-07-2018 08:39 AM
Matt, so you are saying that if one installed a 2,7 or 3,0, with a flat flywheel, that a 225mm pressure plate and disk would not fit in the bell housing of the 923?
So the 923 trans won't accommodate the later 225mm pull type pressure plate?
Matt Monson 10-07-2018 09:23 AM
Gordon,
I don’t know anyone who has ever tried. What I’m saying is that every 912e I’ve seen turned into a 911 and every 923 gearbox I’ve seen used in a 914, used the stock clutch. How would you address push versus pull?
Trackrash 10-07-2018 09:59 AM
Matt, I guess there are a couple of things to consider.
Since all the pressure plates on 911s are the pull type from '70 on and mate to a flat flywheel, I assumed that set up would work in the 923 trans.
I am assuming the release mechanism is the same in the 923 as in the 915. Maybe that is not the case?
For example when I changed from a 901 trans to a 915 trans in my '71 911 I could use the PP and flywheel that was on my 2,2 motor. I only had to change the disk and the throughout bearing to match the newer trans.
So for example if the OP installed an SC motor couldn't he use the PP and flywheel from the SC, but use a '70-'71 disk? The '70-'71 disk is 225mm but has the smaller spline as was used on the 901 trans. I am assuming that the 923 and the 915 share the same release arm.
Matt Monson 10-07-2018 10:11 AM
http://forums.pelicanparts.com/uploa...1538602036.JPG
Trackrash 10-07-2018 10:36 AM
So the release arm is different on the 923 compared to the 915. I would guess that that could be changed? The shaft is the same? Change the fork and the arm on the bottom? Possible? Otherwise using an SC motor would require a custom flywheel?
Flat6pac 10-07-2018 10:39 AM
From 1970 on all pressure plates are matched to
A flat flywheel
The 923 mainshaft will be the same clutch. 215!or 225 pre 72
You probably change guide tube then a 915 pp and TOB with a 911 disc should
work
Bruce
Nditiz1 10-07-2018 10:42 AM
915 from an 86
http://forums.pelicanparts.com/uploa...1538937706.jpg
Flat6pac 10-07-2018 10:45 AM
That guide tube is already larger than Matt s
Bruce
Nditiz1 10-07-2018 10:48 AM
901http://forums.pelicanparts.com/uploa...1538938099.jpg
Flat6pac 10-07-2018 10:51 AM
Gordon. I don’t see a. Reason for a custom flywheelfor a 3.0 because except for bolt holes every thing is the same
Bruce
Nditiz1 10-07-2018 10:53 AM
Bruce
The guide tube has no affect on the PP, clutch, flywheel. It is solely for the TO bearing correct? So that will all stay the same on the 923. Are all surface area of the TO bearing made the same, meaning they will all touch the fingers at the same point no matter which guide tube you use?
Matt Monson 10-07-2018 11:17 AM
I’m not says no you can’t convert a 923 to actuate like a 915. I am a KISS, guy. Keep it simple stupid. If I can put a 911 engine in the car and change NOTHING but the engine, that’s what I’m going to do. A 1977 was a 2.7. If it were my car I would find one and install it.
If 3.0 or 3.2 is your end goal, find a 915 gearbox and install it at the same time. A 923 gearbox is worth $500+/- more than a same or similar year 915. Makes no sense to me to chase all these clutch flywheel bearing work arounds. Again, back to kiss.
Flat6pac 10-07-2018 11:30 AM
The guide tube is a just fit into the TOB slop shouldn’t be part of the guide....
Bruce
Nditiz1 10-07-2018 11:39 AM
Matt,
I'm with your same thinking. I want to keep it as simple as possible.
I'm asking these questions so that I will know if I need to source a different trans.
Sounds to me like it should work without needing to do anything special.
Matt Monson 10-07-2018 11:49 AM
Yep. I personally like how a 2.7 revs. And the 923 has a 7:31 like a 74 had. In my eyes it makes for a nice little middie.
Nditiz1 10-09-2018 04:15 PM
Matt keeping in line with the KISS method, wouldn't a 3.0 bolt the same as a 2.7?
Flat6pac 10-09-2018 05:11 PM
Yes. Pressure plates and flywheel have the same cross section having nothing to do with
Crank bolt count
Bruce
