Targa_PB_78_SC
mike sampsel's Avatar
Injector life o-rings estimates
So in my removal of CIS runners and during the install, I managed to cause some vacuum leaks at the injector o-rings. As the injectors pull out of the sleeve o-ring replacement (injectors) seems simple.
Sleeve o-rings will be more work. So I plan to just do the injector o-rings first. Then check vacuum state and go from there.
Question on injector life for mechanics out there: would you recommend replacing injectors after 113000 miles? While I’m in there replacing injector o-rings anyway...
Old 10-06-2018, 01:58 PM
walt's Avatar
When I had mine out I just soaked them in Berrymans and reinstalled, unless you have an issue I would not replace. Alternately you could send them out for testing or you can test yourself by spraying into jars and measuring output. There is a procedure for this somewhere in the forum.
Walt
82SC 3.0
81SC 3.6
Old 10-06-2018, 03:42 PM
RDM RDM is offline
Coram Deo
RDM's Avatar
The o-rings definitely need to go. If you leave the injectors connected to the fuel lines, you can test them in the car (pulled out of the manifold and put in a clear jar) to see if they are holding necessary pressure when closed and have a good spray pattern when open. Those that don't can be reconditioned or replaced.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
