88 911 cp
jclporsche's Avatar
Fan housing cracks
R&R'ing the alternator in my 88 Carrera and found these cracks in the housing. It feels solid but looks bad with cracks in 3 of the 4 louvers. Having trouble finding one online. Pelican lists it as no longer available. Can it be welded? Any advice much appreciated. JL
Old 09-03-2007, 09:32 AM
Ken911's Avatar
it will need replaced it's magnesium cant weld it. Vertex sells aluminum replacements not sure if pelican carries those or not. the one on my carrera did that, i found another one on e bay for about $40.00 so i didnt have to fork out for the aluminum one.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 09-03-2007, 10:36 AM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
If it's only the ring...but the diffuser vanes are cracked...total reject it...
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 09-03-2007, 10:38 AM
haycait911's Avatar
if interested I have one in the classifieds. Don..
FS- 245 mm 11-blade fan and housing
Old 09-03-2007, 11:07 AM
David's Avatar
The magnesium can be welded, but I don't recommend it since it will probably crack again in short order. I went with a Vertex housing.
Old 09-03-2007, 11:39 AM
88 911 cp
jclporsche's Avatar
Not sure if yours will fit. Mine is #930.106.102.4R
JL
Old 09-03-2007, 01:09 PM
haycait911's Avatar
my part # is 930 106 102 0R. anyone know the difference? will sell separately.
Old 09-03-2007, 01:15 PM
My old '88 had the same cracks, but not quite as bad. I guess I got lucky and was able to buy the Porsche part right before they stopped selling them.
You'll definitely want to replace that part.
Old 09-03-2007, 01:55 PM
88 911 cp
jclporsche's Avatar
I saw some good photos on line, looks like one important difference between mine and one I saw was the thickness of the flange where the alternator bolts on. I placed a straight edge across the fan opening and measured from that surface to the alternator mounting flange (bore). Mine is about 107mm deep. That depth locates the belt pulley, so it has to be correct. What does yours measure? How much you asking for it? Thanks, JL
88 Carrera 3.4 smile making fun mobile
Old 09-03-2007, 09:05 PM
88 911 cp
jclporsche's Avatar
It' not going back in. I can just see my alternator & fan taking flight in my engine compartment at 6800rpm. nuh! It's not going to happen.
Zef, your Targa is beutiful.
Old 09-03-2007, 09:15 PM
haycait911's Avatar
to the face furthest from the fan housing lip, I get 113mm. and the nearest face of the flange, I get 95mm. sorry. Don.
Old 09-03-2007, 09:53 PM
The Chef
Guest
Posts: n/a
I Got A Used One From Tre When I Notice That Mine Had A Crack. Very Reasonable And Cheaper Than New. Good Luck.
Old 09-03-2007, 09:56 PM
88 911 cp
jclporsche's Avatar
I might be able to make it work. How much do you want for it?
Already sold, anyone else have one?
Last edited by jclporsche; 09-05-2007 at 11:15 AM.. Reason: don't need the same pics 2x, he sold it. I'm still looking for one
Old 09-04-2007, 05:20 AM
88 911 cp
jclporsche's Avatar
I think the cracking was caused (or at least contributed to) by the metal strap that holds the housing to the case not being completely tight. I just remember that when I started removing the strap screw, it was easy to turn (not torqued down). And the bottom outside surface of the housing where it sets on the engine case saddle is very worn - looks like from constant movement or vibration against the case.
Go check yours before things get worn!
Old 09-05-2007, 07:58 PM
88 911 cp
jclporsche's Avatar
Finally got it finished! Went with powder coat on the new housing and the old fan. Didn't have any clearance issues with coating. I did have the powder coater mask off the alternator mounting bore and the steel center of the fan. Here is what it cost me:
Alternator rebuilt $156
New fan housing $360
Pwdr coat $125
Total $641
Old 09-30-2007, 04:37 PM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
Cooool and sweeeet....welcome back on the road...!
<IN GAS WE TRUST>
Old 09-30-2007, 04:40 PM
deshetlr's Avatar
Where did you finally find one. Looks great!
Scott
'86 911 Carrera Coupe, PCA, PBC
Old 09-30-2007, 06:07 PM
88 911 cp
jclporsche's Avatar
Vertex, only source I could find.
JL
Old 10-01-2007, 04:31 AM
Cool, glad you were able to get back on the road. I'm amazed that Porsche quit making/selling that part since it definitely seems to eventually go the way of the dodo.
Old 10-01-2007, 06:03 AM
JCL, Did you have fitment issues with the Vertex piece? Others here stated the early units were poorly cast and had to either modify or return for another piece.
Warren & Ron, may you rest in Peace.
Old 10-01-2007, 08:13 AM
