Looking for advice on engine choice
This is not a 2.7 vs 3.0 debate, but more of some experienced advice on purchasing a upgraded 2.7 vs a running 3.0
2.7 has had some work done, carrera tensioners, time certs, possibly valve guides (75 CA motor), have not heard the motor run, will come with all CIS and exhaust to be running
For $2-3k more a running stock 3.0 from an 83. Compression numbers look good and it runs. Not sure of mileage, carrera tensioners done.
Am I better off spending more to get this unkown mileage running 3.0 OR this rebuilt (was running) upgraded 2.7? Putting aside HP and fun factor. Looking at longevity in a semi daily driver.
Old 10-10-2018, 01:51 PM
History and experience shows that no matter how much you spend on a 2.7 everybody looks at it as a core because the expense to build it is very high and to fix problems is over the value of the 2.7.
A 3.0 usually just needs a valve job and a cleanup and can run another engine 100K
Core values presently
2.7. $2 to 3,000
3.0. Core is $6000+
Bruce
Old 10-10-2018, 02:48 PM
Mark Salvetti's Avatar
You really don’t know much about either engine. The timeserts on the 2.7 just brings it up to a 3.0 equivalence in that area.
Unless you know for sure head studs were done, it seems to me that there is at least equal risk in the 2 motors, maybe more in the 2.7 since you don’t know whether the mechanic that did the work knew what they were doing.
Mark
1979 911SC Targa
Old 10-10-2018, 06:16 PM
Under the radar
Trackrash's Avatar
If it were me, I would look at how complete the motors are and if you can see them run.
After that, if you can do a leak down and look at the cylinders to determine their make, it will help your decision.
Keep in mind that the 2,7 is much older and the mag cases usually are needing expensive repairs.
The SC motor will probably need the divilar studs replaced, not a big deal.
IMO if the SC motor has Mahle cylinders jump on it.
Gordon
'71 911 Coupe 3,0L outlawed
Old 10-10-2018, 06:41 PM
Still here
pmax's Avatar
If you are paying a shop, you will easily spend half of that getting that 2.7 reassembled and running.
Longetivywise, there are the averages which favor the 3.0 but that doesn't say much about these two particular engines.
Why is the 2.7 partly disassembled ?
Old 10-10-2018, 07:14 PM
