-   -   New Engine Compartment Light not working and wiring is HOT (http://forums.pelicanparts.com/porsche-911-technical-forum/1010108-new-engine-compartment-light-not-working-wiring-hot.html)
polizei 10-11-2018 06:04 PM
Hi everyone,
In the 11 years I've owned my '87 Carrera, the engine compartment light has never worked. I tried replacing the bulb, and it still didn't work. I've now replaced the entire light assembly (the old one was not looking good). When I turn on the parking lights, the wiring to the engine compartment light immediately gets HOT. I immediately turned the lights off and the wire cooled.
Before pulling the fuse (4th from the front of the car - controls driver side parking lights and engine compartment light), I noticed that both front parking lights worked, but the rear driver side light did not. When I pulled the fuse, the front drivers side stopped working and the engine compartment light wiring stayed cool. I noticed that the fuse was 25 Amp! Bentley calls for a 5 Amp. Yikes...
Any thoughts on what may be the issue?
Thanks!
rokemester 10-11-2018 06:43 PM
I’ll be watching this thread. My engine light used to work after I cleaned up all the contacts. Now it’s not working and hasn’t for a while.
timmy2 10-11-2018 07:23 PM
I suspect your wiring to the light housing is shorting to ground. Likely at the housing.
Fairly common.
polizei 10-12-2018 05:16 AM
Fairly common.
Thanks. I checked the wiring, and it looks like the positive & ground cables are secured well to the housing. I don't see any tears in the wire sleeves. Any suggestions on what to troubleshoot next?
famoroso 10-12-2018 07:18 AM
I fixed my fuse issue, but my fix may not apply. There are several threads here like this one...
http://forums.pelicanparts.com/porsche-911-technical-forum/203865-fuse-drivers-side-running-lights-keeps-popping.html
timmy2 10-12-2018 07:22 AM
Did you test with a meter? One contact on lamp is power, should be no path to ground from it.
al lkosmal 10-12-2018 07:41 AM
+1....power shorted to ground.
wjdunham 10-12-2018 08:39 AM
I had this same problem on my '85 and took me a while to figure it out. I replaced my rusty old light with a new one and wound up blowing the fuse when I turned the lights on. There was a short from the 12V wire to ground that I could measure with a meter. It went away after I pulled the light and let it hang in the air. After trying all sorts of tape and shielding, I finally tried rotating it 180 degrees and that cured the problem. Evidently these can only be installed one way due to the way the ground return is wired up. Hope that helps.
Bill
Missed Approach 10-12-2018 11:07 AM
Hi Polizei- Agreeing with @wjdunham on position- here's a shot from the owners manual (note position) Also- I switched over (no pun intended) to an LED bulb as well- lower voltage, low heat.
http://forums.pelicanparts.com/uploa...1539371165.JPG
Missed Approach 10-12-2018 11:08 AM
...and with the LED bulb:
http://forums.pelicanparts.com/uploa...1539371314.jpg
1979-930 10-12-2018 11:42 AM
I had the same issue. You probably have the positive and negative reversed at the light housing like I did
rokemester 10-12-2018 11:52 AM
Originally Posted by Missed Approach (Post 10213847)
WOW let the sun in baby! Nice upgrade.
86 911 Targa 10-12-2018 11:59 AM
May we have the top secret p/n for the led bulb?
Best,
Gerry
86 911 Targa 10-12-2018 01:13 PM
Light.
Originally Posted by polizei (Post 10213162)
Hi everyone,
Thanks!
Remove the housing, and the bulb, then look for a short on the +12v.
And, verify that the spacer between the housing and the deck lid
is intact.
The spacer serves as an insulator between the +12v and the chassis ground.
Also, the parking lights must be on for the engine compartment light to work.
Not sure about the requirement for the 25A fuse. I think the Bentley is correct.
pm me as need.
Gerry
rokemester 10-12-2018 06:01 PM
I disconnected the engine bay light and cleaned up all the contacts with a Dremel. This is a fine piece of German engineering. Really is more at home in my 66 VW than the Targa. Still no joy by the way.
Missed Approach 10-12-2018 06:02 PM
Gerry- I am searching for the Part Number for the LED replacement, (its been a few years since I made the switch)
rokemester 10-12-2018 07:54 PM
Got the light to come on momentarily, but won’t turn on consistently. If anyone happens to have an exploded view of how the light housing is assembled to deck lid that would be great. I don’t have a spacer or washer that fits between the fixture and engine lid. I tried to turn the light on without the black dome housing on. The light wouldn’t turn on. It almost looks like the two housing retainer clips are contact points (I confirmed they have nothing to do with switch electrics! Although the black housing needs to snug down as tightly as possible) When I put the housing back on the light lit up briefly.
rokemester 10-13-2018 03:59 AM
A good night sleep often helps clear my mind and allows the information I’ve gathered the day before to settle in. In a previous comment here “verify that the spacer between the housing and the deck lid
is intact. The spacer serves as an insulator between the +12v and the chassis ground.” it was said that the housing needs to be insulated from the car body (the deck lid). Often times critical parts/washers are missing when we go to repair our cars. This was the case here. I fabricated a thin hard plastic gasket from a take away food container top. This led to the proper routing of the gray power wire and the brown ground wire to the light.
rokemester 10-13-2018 04:23 AM
Here are a few pics to show insulator fab and wire orientation. http://forums.pelicanparts.com/uploa...1539432705.jpg
http://forums.pelicanparts.com/uploa...1539432761.jpg
http://forums.pelicanparts.com/uploa...1539432799.jpg
I learned that is important to have the wires enter between light housing and insulator and up through hole/slot in housing. This allows black dome cover to fit snug and allow complete movement for the cover switch. Mine is still finicky and I need to give it an extra push to get it to light. Just want to keep the original as I’m guessing the new ones aren’t as solid.
http://forums.pelicanparts.com/uploa...1539433160.jpg
http://forums.pelicanparts.com/uploa...1539433278.jpg
Thanks for the great information from the forum members and the fellow 87 owner who started this thread. This one had been bugging me.
rokemester 10-13-2018 08:36 AM
Best,
Gerry
I have a message into Carmagic to see if they have a LED tube bulb that will hold up to the engine compartment heat.
