1 5/8 Header vs. 1 1/2 Header for 79 3.0
Hi,
I have been searching and searching. I see different opinions. I will hopefully be picking up a 1979 large port engine next week. I want to buy headers. Stock is just 180hp, my plan is to eventually do the cams and pistons. Question; Do I want the 1 5/8 header? Cheers James |
I suggest that 1.5" will suffice with a relatively stock 3.oL in most all instances. much more appropriate for a 3.2
point of reference. the spec911 class allows 1.5" max for 3.oL and a 1 5/8" for 3.2s. the header upsizing helped the stock intake by rule 3.2 to run a bit faster in testing after requiring 1.5" across the board rule was lifted for them after a number of years. at the same time the 3.oL cars on carbs or ITB's out HP the 3.2s by a long shot even with the 1.5". |
1.5" we have done extensive behind the scenes testing of this on a clients car that runs a racing program with 3.0 engines only .. Tried it multiple ways.. Racing only 1.625. Street/track 1.5"
Bigger is not always better |
Thanks everyone!
Just to confirm: more hp with carbd motor and lap faster? |
If you like your low end torque, go small.
For the bone stock 3.0L engine there is no advantage increasing the header primary tubing size to 1.63"OD. Exhaust port size and volume coupled with C/R and cam profile work best with 1.5"OD primary size. Engine modifications that improve breathing and flow will benefit from larger pipes.
the spec911 class requires stock pistons, although you can use the higher compression euro units and stock cams on both the 3.oL and 3.2 motors. the 3.2 motors can be chipped, but must use stock intake and injection. a 3.oL motor can be carbed up to a 46mm weber/pmo or some dam fancy ITB injection systems. I ran 46mm pmo for the last 4 years I raced with PRC as the injection systems were waaay beyond my tax bracket and were in most cases having greater HP than carbs. so to answer your question the 3.oL motors have traditionally been the superior motor from a HP standpoint with either the carbs or ITB injection systems. the rule changes to aid the 3.2's in being more competitive have been the larger headers and some years ago they allowed the more robust G50 3.2's to participate with a somewhat greater minimum weight where as all 3.oL must use a stock geared 915. |
Need to clarify whether inside diameter vs outside, e.g. 1 5/8" outside diam. is 1 1/2" inside diameter.
measured by inside diameter. differing tube material thickness can skew the OD.
I always assumed it was outside diameter.
A what point does a 3 L get the larger header? Their must a point in hp? |
When a bit too small a header is used it is less harmful for most operating regimes than when a bit too large is used. |
Thanks to all who contributed. I will probably get the 1.5 headers. I can always get bigger dependent on the future pistons, cams, twin plug AND the money needed!
Note for everyone.. Tubing is ALWAYS measured OD.. Pipe is measured ID(infrastructure materials)) ALL exhaust is Tubing.. |
Thanks Ben. I Really like your products. Nice to know What the standard of measurement is.
For headers used in competition, diameter is often limited in the class rules packages. Think about measuring for compliance. How do you measure the inside of something you have no access to? You can't. So the rules stipulate the O.D. because that can be easily measured. This is convenient as the O.D. is the only measurement that will equate to standard dimensions. |
Manufacturers will engineer around known and available materials.. |
http://forums.pelicanparts.com/uploa...1539611943.JPG http://forums.pelicanparts.com/uploa...1539612205.jpg |
Now I must inquire...
Is there a different thought path if say someone (SauCy) recently installed the larger of the 2 sized headers in question on a stock 3.0...but that engine is a true Euro spec 930/10 with large intake runners and higher CR...? With an M&K 911R muffler...of course :) |
Brian sorry to disagree but type of material doesn't dictate wall thickness.. More common materials used in stainless are .065, .049, .036.. 304vs 321vs any other type doesn't matter its about what the Mill makes and how big that particular size has for a market.. |
When too big is used a similar effect occurs but in reverse, It's less noticeable because you aren't usually going for max power at the bottom end of the rev range. What does happen is that the flow slows down, the bigger the pipe the more it slows. The issue is further complicated by the use of a muffler. each muffler affects the system in it's own way, adding more or less back pressure. The one sure thing that any muffler does is inhibit acoustic tuning. Stainless is the preferred material for longevity but also adds a small amount of heat insulation. The hotter the gasses, all else being equal, the faster they move the more efficient the exhaust. Some will add external mat insulation but this raises the issue of additional corrosion which will shorten service life. |
911SauCy, are you asking a good question. From the information referenced here it looks like 1.5 is good.
The 930/10 is a common motor used in PCA E class racing. Some of those cars are REALLY expensive builds. I would assume they are using 1.5. I may ask on Renn where some of them post from time to time. |
I think it is/was a matter of semantics. It is true that the type of material does not dictate the wall thickness of tubing from a manufacturing standpoint, it is the application that dictates the thickness.
Here's a comparison of the exhaust gas flow into each pipe/Sec for various engines.
here Volumetric Efficiency is assumed to be 100% and the acoustic effects aren't considered http://forums.pelicanparts.com/uploa...1539800492.gif note that at say 15 l/s; the 2.7 is @ 4000, the 3.0@3800, the 3.2@3200, the 3.6@3000 |
| All times are GMT -8. The time now is 07:36 AM. |
