-   -   Unhappy front end noise- Broken Drop Link (http://forums.pelicanparts.com/porsche-911-technical-forum/1010305-unhappy-front-end-noise-broken-drop-link.html)
Skip Newsom 10-14-2018 12:23 PM
Just prior to leaving on a 2 week vacation I took ye old Targa out for a drive and heard some extra creaking and complaints from the front suspension.
I did put in Elephant Racing front control arm bushings several years back, I do like them but they do seem to get noisier when they need more grease.
I assumed that was the cause of the additional noises so I went after them with a grease gun and a quick check of all the other moving bits after getting back home.
Passenger side all looked OK other than a bit more play in the wheel bearings than I'm happy with.
As I was eyeballing the driver's side the cause of the noise became clear:
http://forums.pelicanparts.com/uploa...1539544538.JPG
Wow!
I do remember hitting a speed bump that was bigger than I initially thought about 3 weeks ago and thinking I may have bottomed out the front suspension travel. It really was not that severe but I believe that was likely the cause of the drop link failure.
I have two new drop links and bushings on order from our host, so both sides will get replaced soon...
Seems like an odd failure. Maybe 46 years is a decent life expectancy from a German OEM drop link?
Anyone else break one without a major impact/force?
