 yes..i have always told my clients not to idle the car .Get in start it and drive is my moto..as is for most of the 911 peeps In this case i do not think is rich.....that is all..it could be many things...as Tony has said too... i just said not to worry too much about it because it is not bad at all...and if the car would be in the right hands in the shop maybe then i would do some test.Again nothing to worry about in this 911 warming up on the drive way before it hits the road... Ivan |
 Any reason why he shouldnt start it with the air cleaner off and push/pull the plate to see which direction helps/hurts the idle? It would seem this could inform if its a rich or lean issue. Wouldnt tell him why (base mixture vs ccp vs other) but its a simple/easy test. |
| All times are GMT -8. The time now is 05:50 AM. |
