Looking for a 2 pc front rotor for a GT Brembo 323 x28
I have yet to find a fixed 2 pc hat and rotor disc for my brembo (Big Red) single pc cast rotors.
These Brembo 4 pot brakes are the older rebel racing big red brakes. Anyone know of a 2 pc fixed rotor replacement ? SPECS: The Race tech specs;GT-1P_.6001A (GT SYSTEMS) | 1986 PORSCHE 911S / SC / CARRERA Brembo front rotor 1 pc 323 x28 Disc Type: Cross Drilled Disc Material/Finish: High Carbon / Corrosion Resistant Plating Disc Diameter: 323mm Disc Width (Measurement): 28mm Disc Air Gap (Measurement): 10mm Disc Annulus (Measurement): 54mm Disc Construction: 1-Piece Disc Disc Vane Design (Measurement): Vented Curved 48 Vane Disc To Hat Mounting System: N/A
1979 SC 1986 Carrera 3.6 L+ |
Why not purchase the original from Race Technologies? Rebel just resold the the Race Technologies kit. We sold a few of them as well. Because the size is odd and not "big" it is unlikely anyone entered the marketplace with a 2 piece replacement...
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Thanks Jeff,
this is what I also have found. your comments seem to verify it. The one piece vented /drilled rotor is cooled sufficiently and stops the 3.6 very well with pagid yellows,so why mess with it if its not broke. Yes, the two piece is lighter and would dissipate heat better,but then again I could also solve the problem with a gt3rs . . So,that brings me back to the nut behind the wheel ,and improving the driver software skills I guess.!!
