-   -   Spark Plugs for 1979 3.0 8.5 Compression? (http://forums.pelicanparts.com/porsche-911-technical-forum/1010487-spark-plugs-1979-3-0-8-5-compression.html)
jamesjedi 10-16-2018 08:44 AM
A lot has changed over the years. Can someone point me to a good spark plug for a car that will be tracked and autocrossed? Thanks
NGK (1233) BPR5EY V-Power Spark Plug?
XP XTREME PERFORMANCE? spark plug?
NGK (6597) BPR5EIX Iridium IX Spark Plug?
Thanks for the help!
T77911S 10-16-2018 10:16 AM
COPPER PLUGS!!!
bosch supers or NGK copper. start with a heat range of 5 (for bosch).
left off the bosch part.
jamesjedi 10-16-2018 11:05 AM
Thanks,
There are so many options. I am certain I am overthinking this.
jamesjedi 10-16-2018 11:40 AM
A Bosch 5 is different from a NGK 5.
file:///C:/Users/Administrator/Desktop/Spark%20Plug%20Cross%20Reference%20HEAT%20RANGE%20 CHART.html
jamesjedi 10-16-2018 02:49 PM
I just bought these. I am finding the choices are many.
NGK 7832 Spark Plug
T77911S 10-17-2018 04:37 AM
7832 crosses to a bp5es or bosch W8D.
that's a pretty hot plug to start with.
jamesjedi 10-17-2018 05:20 AM
I just realized that. The numbers are confusing. It is a plug that EBS sells for these engines. Also, the 78-79 can run with a hotter plug.
I think I need a 7 rating for an EKG.
jamesjedi 10-19-2018 10:59 AM
Thanks for the help.
I will be returning the “hot” plugs and have ordered NGK-BR7EIX-(6664). This would be equivilant to Bosch 5.
