-   -   DIY tool for external oil thermostat cap (http://forums.pelicanparts.com/porsche-911-technical-forum/1010620-diy-tool-external-oil-thermostat-cap.html)
Costa P 10-17-2018 01:26 PM
I eventually succeeded to remove the small cap (oil pressure relief).
This was my 3rd attempt after 2 previously failed attempts....more about those here:
http://forums.pelicanparts.com/911-engine-rebuilding-forum/927868-930-rebuild-revival-my-mothballed-project-6.html#post10202215
I figured it may help someone else to know what worked for me, so here goes:
The mild steel “coin” was from the failed attempts. It twisted without handling much torque. I hacked the high strength steel version out of a chisel! It went into the slot nice and snug with the aid of a hammer.
http://forums.pelicanparts.com/uploa...1539810062.jpg
The high strength steel version got the job done like a breeze. I used a 600mm long power bar with a 21mm socket over the hex of the chisel.
Surprisingly, the tip did twist and deform!
Costa P 10-17-2018 01:37 PM
Removal of large cap (thermostat)
http://forums.pelicanparts.com/911-engine-rebuilding-forum/927868-930-rebuild-revival-my-mothballed-project-5.html#post10187667
I used a friction spanner to loosen the 50mm cap
http://forums.pelicanparts.com/uploa...1539811943.jpg
75 911s 10-17-2018 01:43 PM
Nice! love the custom tool. There's a pretty cool replacement cap that a member makes that has a hex pattern built into it, not that you need it now. :-) I think on mine I soaked overnight with pblaster and then used cut a piece of thick aluminum as a key. Mine was obviously not as "on there" as yours though.
2jmotorsports 10-17-2018 02:40 PM
What a timely DIY. Im about to do this myself.
Also, for your hardlines, I was able to remove mine with no drama soaking with PB Blaster once a day for a few days then hitting each fitting with a propane torch. After about 2-3 heat cycles and the use of these wrenches:
https://www.harborfreight.com/15-piece-metric-service-wrench-set-93668.html
All 4 hardlines came off with no issue.
JimmyT 10-19-2018 07:57 AM
I made these up to simplify the remote thermostat plug removal process.
http://forums.pelicanparts.com/uploa...1539964501.jpg
I also make plugs with hex heads for easier removal.
FS: Remote Oil Thermostat Press Relief Cap, 916.107.276.00 (Small), $21.38
FS: 911 Remote Oil Cooler Thermostat Cap, 911.107.155.00 (Large), $25.62
Costa P 10-19-2018 11:02 AM
http://forums.pelicanparts.com/10133525-post13.html
JummyT, those tools look awesome and the hex caps look even more impressive 👍🏻👍🏻
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
