Slippery slope skier
Costa P's Avatar
DIY tool for external oil thermostat cap
I eventually succeeded to remove the small cap (oil pressure relief).
This was my 3rd attempt after 2 previously failed attempts....more about those here:
930 rebuild – The revival of my mothballed project
I figured it may help someone else to know what worked for me, so here goes:
The mild steel “coin” was from the failed attempts. It twisted without handling much torque. I hacked the high strength steel version out of a chisel! It went into the slot nice and snug with the aid of a hammer.
The high strength steel version got the job done like a breeze. I used a 600mm long power bar with a 21mm socket over the hex of the chisel.
Surprisingly, the tip did twist and deform!
Costa P
'85 930 Grand Prix White ...the oil leak rebuild which mutated into MoTeC EFI+twinscroll GT35R+twinplug+ ...
Old 10-17-2018, 02:26 PM
Costa P's Avatar
Removal of large cap (thermostat)
I used a friction spanner to loosen the 50mm cap
Costa P
Old 10-17-2018, 02:37 PM
Registered Minimalist
75 911s's Avatar
Nice! love the custom tool. There's a pretty cool replacement cap that a member makes that has a hex pattern built into it, not that you need it now. :-) I think on mine I soaked overnight with pblaster and then used cut a piece of thick aluminum as a key. Mine was obviously not as "on there" as yours though.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 10-17-2018, 02:43 PM
Cr@pcan Rescuer
2jmotorsports's Avatar
What a timely DIY. Im about to do this myself.
Also, for your hardlines, I was able to remove mine with no drama soaking with PB Blaster once a day for a few days then hitting each fitting with a propane torch. After about 2-3 heat cycles and the use of these wrenches:
https://www.harborfreight.com/15-piece-metric-service-wrench-set-93668.html
All 4 hardlines came off with no issue.
Jose - 1983 911SC Coupe
Instagram: @joe_engineer
www.joe-engineer.com
Old 10-17-2018, 03:40 PM
I made these up to simplify the remote thermostat plug removal process.
I also make plugs with hex heads for easier removal.
FS: Remote Oil Thermostat Press Relief Cap, 916.107.276.00 (Small), $21.38
FS: 911 Remote Oil Cooler Thermostat Cap, 911.107.155.00 (Large), $25.62
Old 10-19-2018, 08:57 AM
Costa P's Avatar
Auxiliary Oil Thermostat Hex Caps
JummyT, those tools look awesome and the hex caps look even more impressive 👍🏻👍🏻
Costa P
Old 10-19-2018, 12:02 PM
