| MichiganMike |
10-18-2018 11:07 AM |
Another 915 Trans question - 5th gear swapped with reversed 2nd?
Sorry - newbie question here.
I believe I have heard in the past that with a Porsche trans, you can replace the 5th gear for a reversed 2nd gear to gain a lower ratio. I am not sure if this is true or not, but curious if someone can clear this up for me. Maybe it was more true for a 901 or other trans, I cant recall. I have tried to search it on here, but all discuss aftermarket 5th gears, (which leads me to believe this swap isn't possible)
I currently ask because we are rebuilding my 915 trans and would like to upgrade my 5th gear to something lower and have a few gears at our discretion. Note - I do have a 8.31 R&P. With my Subaru motor powering the car, I am already pretty high in revs on the highway, and would def love to lower it to gain even better mpg, and perhaps even less muffler drone :). Motor would be happy around 2500rmp I think, as the car weighs nothing and isn't even under and boost when cruising at 80.
Any help / insight would be appreciated. TIA!
