Driver side window rattle
Hi everyone! As the cold weather rolled in I started hearing a rattle in my 88 911 Targa coming from behind the driver side door window. I was able to reproduce by shaking the window manually (if I do the same on the passenger side it doesn’t do it). See video here:
https://youtu.be/8BwInD3XnHs I did some research in the forum and found the following threads: http://forums.pelicanparts.com/porsche-911-technical-forum/975235-drivers-side-window-rattling.html http://forums.pelicanparts.com/porsche-911-technical-forum/163612-911-electric-window-rattle-fix-3.html Do you guys think this is related or something else? Thanks! Sent from my iPad using Tapatalk |
Update: did a quick inspection by removing the panel but everything was very tight. I also checked and can confirm that the noise only happens when all the way up. That wasn’t what I experienced during driving (as it would make that rattling noise with window all the way up, middle or completely down).
Any ideas? Sent from my iPad using Tapatalk |
| All times are GMT -8. The time now is 05:56 PM. |
