-   -   915 Transmission shift 3-4-5 problem (http://forums.pelicanparts.com/porsche-911-technical-forum/1011312-915-transmission-shift-3-4-5-problem.html)
hbrand 10-25-2018 02:03 PM
The shifter in my 1978 Porsche 911 has no resistance going to 3-4 -5th gear.
1-2 gear is spring loaded to the left, but when I go for 3rd gear I easily end up in 5th gear with zero spring load.
Is the problem the shifter or the transmission ??
I bought the car that way.
Thanks, and greetings,
Harold
pete3799 10-25-2018 02:59 PM
A stock shift lever is not spring loaded to the left. Only 5th and reverse are spring loaded.
You may have an aftermarket set up. Take a picture of it.
Trackrash 10-25-2018 03:42 PM
Could be shifter bushings, shift rod coupler, or the guide fork in the transmission came loose.
Pull up the shift boot and take a picture so we know what shifter you have.
Flat6pac 10-25-2018 03:47 PM
I’ll put the money on the guide fork on the inspection plate
If that’s the fault replace the whole plate and fork, don’t try to fix it
Bruce
hbrand 10-26-2018 07:25 AM
Murphy's Law wins again
Part 3 in the drawing is installed upside down. This puts the shifter spring loaded to the left side.
What a crappy thing to do.
Greetings, and thanks
http://forums.pelicanparts.com/uploa...1540567437.jpg
hbrand 10-26-2018 11:52 AM
more shifter woes
Turning part 3 around would also not work.
The shift fork is for a standard shifter while all other parts are
from a short shift kit.
So need a short shifter shift fork. WOW
911pcars 10-26-2018 04:03 PM
There's no indication in your text you have a 930 gearbox, yet that illustration shows a 930 shift housing.
An early SC 915 shift housing illustration follows:
http://forums.pelicanparts.com/uploa...1540598044.png
Not sure why your factory stock 915 shift lever has spring tension on the 1/2 side. Typically, only on 5th/Rev. AFAIK, a 930 4-speed turbo shifter doesn't have any springs
The issue may be due to a worn front shift shaft bushing (item 22 above). Excess play here prevents the lever from selecting the proper gears.
http://forums.pelicanparts.com/uploa...1540597745.jpg
Sherwood
