Roll the windows down, gettin smokey in here. (oil leak)
I have an elusive oil leak that drips in the left side heat exchanger, not all the time but just when you come to an abrupt stop after a drive of 50-60 mph. Of course I can't get it to leak at all when the car is on jackstands.
Has anyone else had a similar leak that might could put me on the right track to a repair?
1973.5 911T ——-1974 914/1.8
Old 10-24-2018, 08:30 AM
proporsche's Avatar
take a picture from the bottom of the engine and we will tell you what is up..
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 10-24-2018, 08:33 AM
Leaking triangle most likely oil light sender they leak around the crimp gets down around the oil cooler. Leaks more at higher rpms. There was a thread lately someone filmed it with their phone.
Old 10-24-2018, 02:28 PM
Thank you. Makes sense. I'll check it out.
Old 10-24-2018, 03:17 PM
El Duderino
tirwin's Avatar
Would the sender produce enough oil to smoke?
I was wondering if maybe the crankcase breather hose has come loose?
Either way, same area.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 10-24-2018, 03:24 PM
Can the sender be accessed with the motor in the car?
Old 10-29-2018, 08:22 AM
Flojo's Avatar
What engine is in your car?
Do a search here in forum for "trangle of death" to get an impression, lots of threads and pictures.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 10-29-2018, 09:24 AM
Flojo is right; best to know what engine you have...
For 3.2, the sender / TOD can be accessed with the engine in, but it is VERY DIFFICULT/impossible unless you:
  • Remove blower motor / heater ducting
  • Remove air cleaner
  • Do a partial engine drop and lower the engine 4-5 inches (search for threads here on best way to do this)
This way you will have half a chance to clean it up and check on leaks back there.
Good luck.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 10-29-2018, 09:45 AM
Originally Posted by flojo View Post
what engine is in your car?
Originally Posted by lyle o View Post
flojo is right; best to know what engine you have...
For 3.2, the sender / tod can be accessed with the engine in, but it is very difficult/impossible unless you:
  • remove blower motor / heater ducting
  • remove air cleaner
  • do a partial engine drop and lower the engine 4-5 inches (search for threads here on best way to do this)
this way you will have half a chance to clean it up and check on leaks back there.
Good luck.
2.4 cis
Looks like a motor drop is needed. I think I'll drive it until the (weak) clutch goes out.
Old 10-29-2018, 09:57 AM
