911 carrera 3.2 (1985)
kees's Avatar
Porsche Crest Threshold Rubber Step Plate
I'm in the progress of replacing the original threshold rubber step plate, which has shrunked over the years. The old one was glued, but the new one comes with two strips of adhesive tape.
Do I need to add some additional sealant or glue when I put it on the threshold?
I am afraid that otherwise moisture will be retained.
Thanks,
Kees
Old 11-06-2018, 09:34 AM
Actually, as long as the "gap" areas are not sealed on their ends, moisture should not be retained, as it can drain or evaporate away. Alternatively, you could remove the adhesive strips entirely and use semi-liquid adhesive. But I would just go with the adhesive strips already there...
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 11-06-2018, 10:14 AM
4flyboy's Avatar
I used the adhesive strips here in Florida with no issues Kees...
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 11-06-2018, 11:39 AM
kees's Avatar
Thanks Lyle and Scott
Old 11-06-2018, 01:15 PM
