Driven gear oil
Trying to get info on Driven gear oil.
G50 tranny no limited slip.
Driven gear oil options are...
75w-85
75w-90 limited slip
75w-110
75w-140
Which one would be best ?
Old 11-08-2018, 08:15 AM
Spiderman
Jesse16's Avatar
Either of the first two are fine. If they are GL-5 rated and most people here seem to prefer synthetics but I'd say no issue with cold in LA. The limited slip version of gear oil has an additive for the LS function that's not needed on non-LS gearboxes (obviously LS gearboxes still have gears so of course).
Never heard of using the heavier weight oils on our cars.
Mexico Blue 87 Carrera
Red 18 Honda HRV, wifes car
Black 12 VW-GTI, work
Red 08 Impreza, wifes car sold
Grey 05 CRV, now is the daughters solution
Old 11-08-2018, 08:39 AM
75w-90 as long as its GL-5 rated.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-08-2018, 08:50 AM
I like the Driven lubrication products quite a bit. That said you may also want to investigate Amsoil who also make a gear lube designed for limited slip that also has an additive to protect synchros on vehicles with transaxles.
Brian Miller - Scottsdale, AZ
1962 Devin C :: 1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S
Old 11-08-2018, 10:38 AM
In a thread some weeks ago Bill V posted a chart with viscosity info on several different brands of synthetic gear oil for use in a G50. Very good info. The low temperature viscosity covered a big range, where the 100 degree C viscosities were all close to one another.
Old 11-08-2018, 10:52 AM
I do not have limited slip. The Driven gear oil 75w-90 is for a limited slip tranny. Can I still use it ?
Old 11-09-2018, 06:39 AM
Spiderman
Jesse16's Avatar
Short answer is yes.
Old 11-09-2018, 07:42 AM
Ok, did some searching and found some Gl-5 Driven Gear Oil 75w/90 without limited slip at Summit Racing. The Driven web site did not list this , nor does the LN Engineering site.
Got 4 qts ordered !
Old 11-12-2018, 12:02 PM
Got the 75w-90 Driven gear oil. I will be using CLEAR hoses next time !
I do notice better cold shifts. Once warm, pretty much the same as the Delvac.
Old 11-25-2018, 05:46 AM
