sugarwood's Avatar
Heater blower issues. Here's what I checked.
It's getting colder, and it's time to turn up the heat!
I pulled up the levers, and spun the dial to 3, and got nothing.
Actually, I tried 0,1,2,3 and none of the dial settings worked.
Footwell blowers are dead.
I took off both the footwell covers and checked the 2 fuses.
They were intact, and I verified continuity with my MM, to be sure.
So, they fuses are not blown.
I opened the engine lid and put the key into ACC (key buzzing, but engine off)
I pulled up the levers, and spun the dial to 3.
Engine blower is silent. (Engine blower was new 2 years ago)
I believe the engine blower motor should turn on at this point
It would be very rare for both footwell blowers and the engine blower to all stop working simultaneously.
Next step would be the switch?
But, what are the odds that BOTH red lever switches die at the same time?
So, this makes me think it might be some kind of relay downstream from both red lever switches.
What's the next step? Check the engine compartment relay?
SOLVED
Summary:
* I verified the footwell blower fuses were intact.
* I checked fuse #8 in the frunk was intact
* I tested my blower relay in another 911, and it worked.
* I also verified the 3 fuses were intact.
* I verified pin #12 for that engine bay relay harness gets voltage.
* Then I found the culprit.
Blower motor was disconnected.
Capture
1986 3.2 911 coupe.
Old 11-08-2018, 02:57 PM
sugarwood's Avatar
I want to swap out this relay to see if this is the culprit.
But, how do I remove this?
Do I need to remove the entire bracket assembly?
The harness that the relay connects to seems like it's floating wet noodle
so if I pull it off, I don't think I can push it back on.
1986 3.2 911 coupe.
Old 11-08-2018, 04:35 PM
old man neri's Avatar
The way the relay works, to my understanding, is if the rear blower is not working the foot well blowers won't engage.
I had this issue, turned out to be a quick fix. The fuse for the engine blower was corroded.
I would look at the fuse and the relay. Both of these are the left of the engine. The relay is expensive to replace/hard to find so be careful with it.
Old 11-08-2018, 05:24 PM
Next step ?
Dig out the multimeter and start measuring voltages.
I can't afford that.
Old 11-08-2018, 05:51 PM
sugarwood's Avatar
Do you mean the 3 blue fuses in the photo?
None of them are blown, and I spun them around to clean the contact point.
That did not fix it.
I do not know how to remove the relay box.
The harness base did not seem to be attached to anything,
so the whole attachment is very floppy.
1986 3.2 911 coupe.
Old 11-08-2018, 06:39 PM
sugarwood's Avatar
Originally Posted by pmax View Post
Next step ?
No idea what to test.
I need step by step directions meant for an idiot.
In the meantime, I will try to swap it for a known working one.
1986 3.2 911 coupe.
Old 11-08-2018, 06:59 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Woody, what you do is unscrew the bolt that holds the relay case to the board and then gently lift up - you will see that the harness plug for it is not attached to the board and there is some slack to that you can at least partially pull it through the board opening . . . then you remove the relay and will be able to re-attach another one since some of the harness socket will be up high enough for you to get a couple of fingers on it .
If there isn't enough slack, then you can loosen or remove the top two nuts that hold the board to the inner fender and the scooch it forward enough to give the harness some room to move (don't need to remove it). BTW, it is a good idea to disconnect the negative lead to the battery before doing any of the above.
Old 11-08-2018, 07:09 PM
Is your search function broken or you need that heat tonight ?!
Here... post even has a nice pic.
Carrera - Removing Engine Compartment Heater Blower
Old 11-08-2018, 07:56 PM
1988 Carrera
shadowjack1's Avatar
the first thing I would check is are you getting power to the blower motor. Then check the ground. Did you change the alt in the past, the ground for the blower connects to the alt housing. It does on an 88 any way.
88' Carrera
79' SC gone (lost to Katrina)
75' Targa gone
72'914 gone
72' 914 gone too
Old 11-09-2018, 04:55 AM
sugarwood's Avatar
Why is that electrical diagram for me?
It seems to be how to make a new double relay.
Not sure how that helps me "Dig out the multimeter and start measuring voltages."
I asked for directions on how to test my relay, not build a new one.
Everyone I know with a 911 has already mothballed their 911 off-site for winter
So, I am unable to acquire a 2nd relay.
Anyone know how to test the relay?
Otherwise, I can just spend the $500 for a new relay and hope that it works.
1986 3.2 911 coupe.
Old 11-09-2018, 09:47 AM
Check the ground #9 , power #12 , bypass #12 to #4 etc etc
then decide if you can afford $500 for a new relay or make one yourself.
Get on with it, Sugar !
Old 11-09-2018, 10:04 AM
sugarwood's Avatar
Ok, I figured out how to remove the square relay box.
(I stuck my fingers underneath and base and pushed it up and out of the cavity.)
Now that I have the relay out, any idea how to test it?
I have a MM but barely know how to use it.
I have some old notes in here
1986 3.2 911 coupe.
Old 11-11-2018, 10:07 AM
sugarwood's Avatar
What do you mean "check the ground #9" ?
I have a male pin on my relay box that says 9.
I also have a female #9 hole in the harness.
Which one are you referring to?
I have a MM.
Can you tell me EXACTLY where to connect the red and black lead?
Same question applies to the other 2 statements
"Power to #12"
"Bypass #12 to #4"
Here is more from another thread:
Pull the relay out.
Check pin 30 for power. Bypass 30 to pin 87 using a wire, the motor should run if it's ok. If not, trace the connectors from the blower, make sure it's plugged in.
The lever switch grounds pin 85 activating the relay. 86 is power.
Check the middle fuse too.
1986 3.2 911 coupe.
Old 11-11-2018, 02:28 PM
sugarwood's Avatar
How do you open up this relay box?
I would like to see if anything looks broken inside.
Also, I only see pins #1-12 on the relay.
I don't see one post in 20 years with directions how to test the relay.
Weird.
1986 3.2 911 coupe.
Old 11-11-2018, 02:47 PM
sugarwood's Avatar
Here is another post from Renn.
Can anyone help me translate this into directions for a n00b ?
Which is the positive terminal on the relay? Does he mean fuse?
You need a volt meter.
Turn ingnition switch to all the way on, but do not start the car. Then turn your auto heat dial (between the seats) to any on position. Make sure the lever moves upward a bit.
Go to the relay with the volt meter. Touch your negative lead to the metal surrounding the rely. Touch the positive lead to the positive terminal on the relay. (if memory serves this is the 3rd fuse). If your needle moves you have juice to the rely.
Now, on the right side of the blower motor there is the wire connector to the blower. Unplug the connector. Touch the leads to the separate points on the connector. Switch leads to make sure you have pos/neg right. If needle moves on either way the relay works and the fan is shot.
Hope this helps. This is what I did to determine that my relay was fine and the fan was kaput.
1986 3.2 911 coupe.
Old 11-11-2018, 02:49 PM
The numbers are on the relay you just removed !
I'm not going to hazard into any exact instructions over the interweb ... given this is electrical stuff, you can accidentally short something and cause further damage. Time to call a pro if this is beyond your comfort zone ?
Old 11-11-2018, 03:21 PM
sugarwood's Avatar
Read the first paragraph in post #13
1986 3.2 911 coupe.
Old 11-11-2018, 05:21 PM
sugarwood's Avatar
Might all be a moot point.
I installed a working relay from another 911,
and my heater still did not work.
I have 2 footwell blowers. Fuses are good.
I have 2 red levers, a dial from 0-3, and an engine bay blower motor.
If the red levers are bad, do they go bad together?
They work off 2 different switches, since they control independent footwell blowers.
So, it's next to impossible that BOTH red level siwtches would fail at the same time.
No idea where to go from here
1986 3.2 911 coupe.
Old 11-11-2018, 05:24 PM
Again, the footwell blowers will not work unless the main blower in the back starts working. Have you tried bench testing it? Have you tried seeing if you get 12V there once you crack open a red lever?
Old 11-12-2018, 05:51 AM
sugarwood's Avatar
The main blower is brand new.
But, I will test to see if it's getting voltage.
(I predict the answer is no)
Which will not help me isolate the real problem
I need to look up how to test for voltage.
Have not done it in a few years.
Does anyone know how to test if the relay is getting power?
If it is not, that points to the levers.
20 years of archives,
and I could not find a single post on how to test the red levers.
1986 3.2 911 coupe.
Old 11-12-2018, 09:42 AM
