Bill Verburg's Avatar
Originally Posted by dw1 View Post
According to the Car and Driver magazine review of the US-spec 911SC in the Aug 1980 issue: 130 mph.
Maximum speed in each gear:
1 - 37 mph
2 - 65 mph
3 - 94 mph
4 - 118 mph
5 - 130 mph
By comparison, in a C/D Feb '84 article, the 1984 US-spec 911 Carrera speed in each gear is given as:
1 - 37 mph
2 - 66 mph
3 - 93 mph
4 - 117 mph
5 - 149 mph
max revs used in 5th was 6000
max revs was 6300
Bill Verburg
Old 11-11-2018, 06:29 AM
Senior Member
Superman's Avatar
As I say, my car 'feels' like it's got the power to reach 6300 to 6800 in fifth gear. Here are some other facts and perceptions:
My engine is, I think, the 930/10. It came from an '83 SC and has been freshened, using the stock 9.3:1 pistons. torquey. 20/21 cams and small diameter intake runners. SSI heat exchangers, two in two out Triad final exhaust.
I recently had the Bilstein shocks and strut inserts revalved for the upgraded torsion bars (22/29, I think) and Rebel Racing breathed on the struts themselves. Conti Extreme Sport tires, which I like very much. The car has the factory chin spoiler and aftermarket fiberglass Carrera-style tail. This car gets to 110 mph in a hurry and feels perfectly planted at that speed.
Old 11-11-2018, 08:40 AM
RDM RDM is offline
Coram Deo
RDM's Avatar
I had mine up around 5500 rpm and it was about all it could do. Wish I knew how fast it was but only 85mph spedo. It felt very fast. We did 135 in my brothers gti on the same stretch and it felt nowhere near as fast. Cant imagine ill ever try that again it was sketchy
It was twice as fast as 2750, whatever that is.
Definitely sketchy above 110 or so. The front lip makes a huge difference at those speeds.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
1990 Mercedes 250D Opawagen • 2002 E270 T CDI Familienwagen
Old 11-11-2018, 08:58 AM
Crotchety Old Bastard
RarlyL8's Avatar
The engine in my SC was similar, Euro spec with SSI, so the power is adequate to get there. I had no problem hitting redline in 5th on many occasions. The actual final speed of course depends on tire height and trans gearing.
Old 11-11-2018, 09:20 AM
US '83 SC would be a 930/16, 9.3, 180hp/189lbft, hard to say what it is now w/ the mods but probably ~+10-15hp
RoW had the 930/10, 9.8, 204hp/190lbft
Bill Verburg
Old 11-11-2018, 09:42 AM
Senior Member
Superman's Avatar
On a chassis dyno, it made 186 horsepower, and 186 lb/ft of torque, at the wheels. It's pretty healthy.
Old 11-11-2018, 10:01 AM
so that's 204 - 212 hp at the flywheel which is what the factory reports
Bill Verburg
Old 11-11-2018, 10:06 AM
Senior Member
Superman's Avatar
I think the factory says the engine makes 185 or something. Yes, mine is in the neighborhood of 205-ish. The heads and cylinder tops were flycut during the rebuild, and I think the copper base gaskets I used were, stock rather than thicker. Net effect is that my CR is probably north of 9.3:1 now. Timing is advanced about 5-7 degrees compared to stock, and this particular engine does not knock. I'd rather have a 3.8RSR engine, but am happy with this 3.0
Old 11-11-2018, 10:39 AM
Originally Posted by fred cook View Post
I've had my SC up to 7,000 rpms in 4th gear which should be 140 or thereabouts. Of course, the engine is a 3.3SS with big port heads, cams, etc! There was more but I really wanted to keep my license!
If you’re doing 140 you’re deep in licence nullification territory. Might as well find the top of already committed.
But seriously people - take it to the track. If the straight is not long enough, find a better entry speed to the last turn. Or go to an airport day.
Old 11-11-2018, 11:07 AM
The Mighty Pieholio
Bob Kontak's Avatar
FWIW, my 81 heads were done by EBS in the late 90's. -0.006 was stamped on each head. 930/16.
I did some calculating using the cylinder volume formula and it spit out 9.5:1 vs. 9.3:1.
Posted my findings here and it was validated.
Stock gasket kit. It ain't much but has to help a smidgen.
1981 911SC Targa
Old 11-11-2018, 11:39 AM
You guys with 915 trans that can't do 150 are most likely looking at a tired motor.
Old 11-11-2018, 12:05 PM
The Mighty Pieholio
Bob Kontak's Avatar
I don't think an unmolested US spec SC will hit a genuine 150mph. The early 3.2's stand a much better chance with 20+ HP.
1981 911SC Targa
Old 11-11-2018, 12:18 PM
Here are the actual acceleration curves for a friend '78 SC, The motor was blueprinted and runs headers, tires are 275/35 x15, aero is SC-lip + whale, car is lowered, rear wheel hp from dyno 191.4, top speed is 142mph@6750
Bill Verburg
Old 11-11-2018, 12:49 PM
Formerly known as Syzygy
Canada Kev's Avatar
I imagine he would have been only limited by gearing with a tire that's about 23" dimeter. Two inches less makes quite a difference. Or so my last girl friend told me...
Kevin
Old 11-11-2018, 01:37 PM
You are correct as to the effect but a 245/45 x16 would only provide a little more top end, 145@6500 aero limited, 225/50 x16 would be 146@6750 again aero limited
Bill Verburg
Old 11-11-2018, 01:53 PM
142 mph if pushed off the ramp of a C-17 at 20 K. Just kidding, my '83 has seen 105 and that's all, folks.
Don Newton
“People sleep peaceably in their beds at night,” George Orwell wrote, “only because rough men stand ready to do violence on their behalf.”
Old 11-11-2018, 02:09 PM
Eva
911SauCy's Avatar
I've been to about 115 with a lot left...
I'm sure wheel/tire combinations would cause a considerable difference in top speed application to application. My last w/t setup was 17" euromeisters with 255/40 rears. Current is 16" BBS with 245/45 rears... This has made a very notable difference in highway speed cruising RPM. I was about 72mph at 3k, not it's about 68...
Probably going to upsize again because that small difference sure makes the car feel old when trying to keep up w modern traffic
'78 SC Targa ~Eva~
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 11-12-2018, 05:37 AM
I had my mechanic install a 7:31 R&P when I rebuilt my 915, so that I could only go as fast as 120. That's all I need for back stretch at Willow. Wouldn't want to go any faster on Freeway. To old for that!
Old 11-12-2018, 06:07 AM
Senior Member
Superman's Avatar
Hoping the gurus (Dr. Verburg and others) will revisit this thread, I have a new question. 7:31 R&P. Like Slant, I don't have a need to drive at 150 mph. A 7:31 R&P would tighten the gear ratios and (I assume) give stronger acceleration. Moreover, it would allow 65 mph cruising at engine speeds above 2800 rpm. There is exhaust drone in my car at engine speeds below 3000 rpm, and this would fix that. Speak to me, oh wise ones, about 7:31.
Old 11-12-2018, 09:45 AM
I wouldn't
Here's what my friends above 3.0 SC would look like w/ 7:31 cwp
59mph @3000 in 5th
Bill Verburg
Old 11-12-2018, 10:10 AM
