Ignition coil
Anyone have any recommendations for a replacement ignition coil for an '84 Carrera? Something other than the Bosch replacement part or a Porsche coil?
Maybe an MSD. If so, what part number is the correct one? Thank you.
"Life is good" |
The Parts Klassik is the most authentic repro. If you use an MSD it needs to be mounted vertically. Sent from my iPhone using Tapatalk
Bone stock 1974 911S Targa. 1972 914/4 Race Car |
I believe Parts Klassik makes a CDI coil. This will not work well with the 84 Motronic ignition system.
Guys, thank you for responding. This is for a friend.
I had to replace the coil in my 911SC. I made the mistake of buying the Bosch silver coil - it lasted less than a year. I got the MSD that Peter Zimmerman recommended and it has been great.
"Life is good" |
So, what CAN one use as a better coil replacement for a 3.2 with motronic?
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
Not sure if this suits a 3.2 but might be worth asking Jonny Ignition Coil - Classic Retrofit
Very good question.
Dan T '85 Carrera Dansk premuff/sport muffler 7's and 8's, Steve W chip Kuehl AC and fresh top end |
I go t one from NAPA once. It looked exactly like the original, but a different color.
MSD Blaster 2 High Vibration
8222 is epoxy filled and doesnt need to be mounted vertically. Just posted the same question. I bought two...
Speedo |
Always learning
There Appears to be a variety of coils available on the pelican website for a stock 1985, 3.2 (S. Wong chip). Any idea which is the best one? Best value?
The 3.2 Carrera coil in black [Bosch] is used across the Porsche line. 944, 928, 911
The recyclers should have a stack of them Bruce |
