Ignition coil
Anyone have any recommendations for a replacement ignition coil for an '84 Carrera? Something other than the Bosch replacement part or a Porsche coil?
Maybe an MSD. If so, what part number is the correct one?
Thank you.
"Life is good"
Old 04-13-2018, 03:13 PM
Charles Freeborn's Avatar
Thank you.
The Parts Klassik is the most authentic repro. If you use an MSD it needs to be mounted vertically.
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 04-13-2018, 06:29 PM
I believe Parts Klassik makes a CDI coil. This will not work well with the 84 Motronic ignition system.
Old 04-13-2018, 07:52 PM
Guys, thank you for responding. This is for a friend.
I had to replace the coil in my 911SC. I made the mistake of buying the Bosch silver coil - it lasted less than a year. I got the MSD that Peter Zimmerman recommended and it has been great.
"Life is good"
Old 04-14-2018, 03:29 PM
wrxnofx's Avatar
So, what CAN one use as a better coil replacement for a 3.2 with motronic?
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 04-14-2018, 10:09 PM
Not sure if this suits a 3.2 but might be worth asking Jonny Ignition Coil - Classic Retrofit
Old 04-14-2018, 11:00 PM
carreradpt's Avatar
Very good question.
Dan T
'85 Carrera
Dansk premuff/sport muffler
7's and 8's, Steve W chip
Kuehl AC and fresh top end
Old 04-15-2018, 12:43 PM
I go t one from NAPA once. It looked exactly like the original, but a different color.
206 637 4071
Old 04-15-2018, 04:02 PM
MSD Blaster 2 High Vibration
8222 is epoxy filled and doesnt need to be mounted vertically. Just posted the same question. I bought two...
Speedo
Old 04-15-2018, 05:48 PM
Always learning
There Appears to be a variety of coils available on the pelican website for a stock 1985, 3.2 (S. Wong chip). Any idea which is the best one? Best value?
Old 11-12-2018, 03:00 AM
The 3.2 Carrera coil in black [Bosch] is used across the Porsche line. 944, 928, 911
The recyclers should have a stack of them
Bruce
Old 11-12-2018, 08:33 AM
